Go to Post po-nos, cancans, and totes ma goats - dubiousSwain [more]
Unread 26-07-2008, 23:11
Re: pic: Base Idea
You will want to support your transmissions more than you are, with four contact points instead of just two. Either support the two rear bolt points on the transmission or support the two upper front bolts. There would be flex during an impact that would leave your transmissions misaligned afterwards.
GitHub
pic: drive base idea dbell Extra Discussion 23 26-07-2008 11:11
Circle base vs. Rectangle base Pelicano234 Technical Discussion 13 15-01-2008 16:49
pic: Entire base Redo91 Robot Showcase 4 17-02-2007 12:24
pic: "Driveable Base" Cody Carey Extra Discussion 6 27-01-2007 23:29
pic: 1024 Base Michael Long Robot Showcase 4 17-02-2006 08:53
