Re: pic: Base Idea
ok this is whats going on:
the wheels are 5in plywood our team has much experience with them and they have never failed us. the treads are contact cemented and then wood screwed in. yes its 35 chain if its going to defense. the tensioner s are sprockets that are in a slot the movement is controlled by 2 vertical screws each. the axles are all supported in only two places. and thanks for bringing up the pneumatics i never actually thought of it not fitting but i believe it will fit. also the am ss are supported with 4 .25" bolts. |
| pic: drive base idea | dbell | Extra Discussion | 23 | 26-07-2008 11:11 |
| Circle base vs. Rectangle base | Pelicano234 | Technical Discussion | 13 | 15-01-2008 16:49 |
| pic: Entire base | Redo91 | Robot Showcase | 4 | 17-02-2007 12:24 |
| pic: "Driveable Base" | Cody Carey | Extra Discussion | 6 | 27-01-2007 23:29 |
| pic: 1024 Base | Michael Long | Robot Showcase | 4 | 17-02-2006 08:53 |
