Go to Post "Field orientation is like a homing pidgeon that can fly backwards." - LostWolf [more]
Unread 27-07-2008, 16:24
qnetjoe qnetjoe is offline
AKA: Joe Daily
qnetjoe is on a distinguished road
Send a message via AIM to qnetjoe Send a message via MSN to qnetjoe Send a message via Yahoo to qnetjoe
Re: pic: Base Idea
Looks good. Here a couple of suggestions:
1) I would take a look at self aligning bearings. By the looks of it you are just using a standard flange bearing. How are you retain the bearings
2.)You might also consider putting the sprockets on the outside of chassis as it would be easier to work on once you put a mechanism on top.
3.) Consider modifying it so you can easily remove an entire side of the chassis.
4.) You have a large rectangular piece of tubing for the inside mounting rails. That seems a little excessive. You might just consider mounting you entire wheel assembly into a large piece of tubing instead.
Hope this helps
pic: drive base idea dbell Extra Discussion 23 26-07-2008 11:11
Circle base vs. Rectangle base Pelicano234 Technical Discussion 13 15-01-2008 16:49
pic: Entire base Redo91 Robot Showcase 4 17-02-2007 12:24
pic: "Driveable Base" Cody Carey Extra Discussion 6 27-01-2007 23:29
pic: 1024 Base Michael Long Robot Showcase 4 17-02-2006 08:53
