#10
Re: pic: Base Idea
the axles that run thru the bearings are drilled and taped for 10-32s so the bearings will be kept in by washer and bolt. also the sides are easily detachable for servicing sides are held together by standoffs. we run the same type of system on our gear drive base for the sides and it comes apart in a minute with a drill.
| pic: drive base idea | dbell | Extra Discussion | 23 | 26-07-2008 11:11 |
| Circle base vs. Rectangle base | Pelicano234 | Technical Discussion | 13 | 15-01-2008 16:49 |
| pic: Entire base | Redo91 | Robot Showcase | 4 | 17-02-2007 12:24 |
| pic: "Driveable Base" | Cody Carey | Extra Discussion | 6 | 27-01-2007 23:29 |
| pic: 1024 Base | Michael Long | Robot Showcase | 4 | 17-02-2006 08:53 |
