Go to Post Also, If I am not mistaken, the name indicates that your robot is female :P They're all female... like cars, ships, and airplanes. - JVN [more]
Unread 04-08-2008, 11:43
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
pic: Alluminum wheel #1
Unread 04-08-2008, 11:44
RMS11's Avatar
Safety!!!!
AKA: Rick
Re: pic: Alluminum wheel #1
I would love some feedback. Without treads this wheel weighs .68, ours last year were 1.5, we are looking to cut weight anywhere possible. Also how do other teams attach treads?
2009 Palmetto Regional Champs
Unread 04-08-2008, 12:36
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
1323 uses rivets and washers
R.C.
MadTown Robotics Team 1323
Unread 04-08-2008, 13:03
artdutra04's Avatar
VEX Robotics Engineer
How it is going to be manufactured?
If it is going to be made on a milling machine, you can't have square inside corners. You can ignore this if it's going to be fabricated via waterjet/laserjet/EDM, as they can make sharp corners with no problems.
Art Dutra IV
世上无难事,只怕有心人.
Unread 04-08-2008, 13:16
RMS11's Avatar
Safety!!!!
AKA: Rick
Waterjet
Unread 04-08-2008, 13:22
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Originally Posted by RMS11 View Post
Waterjet
You ought to fillet the inside corners anyhow; it'll better distribute stress through the part.
--Madison--
...down at the Ozdust!
Unread 04-08-2008, 13:42
Francis-134's Avatar
Francis-134 Francis-134 is offline
Lifer
FRC #0190 (Gompei and the Herd)
Francis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond repute
Many teams use rivets along with an adhesive to hold the tread to the wheel. You may find it better if you cut the tread so that it slowly ends at a point, instead of just a complete horizontal cut. This will reduce the bunching of the material that happens when you rivet it to the hub.
Imagine the tread when spread out on a flat surface as a parallelogram instead of a rectangle.
Email | Twitter | Facebook | YouTube | Twitch
iTunes Podcast | Snapchat
A proud alumnus of teams 134 and 40 || Mentor of Team 190 || Director of Fun for BattleCry@WPI
Unread 04-08-2008, 15:26
R.C.'s Avatar
Which kind and where do you find it, a link would be nice.
thanks in advance,
-rc
R.C.
Unread 04-08-2008, 16:43
Lifer
thanks in advance,
-rc
I have seen teams use Black Loctite (otherwise known as Loctite 438 Instant Adhesive) with great success. Simply apply it to the tread, place it on the wheel and hold it down tightly with a hose clamp. Once the tread has been secured to the hub (leaving a few hours for it to cure completely), then rivet it down to the metal.
You should be able to find Black Loctite at any hardware store (Home Depot, Lowes, etc.). Here is a link to the data sheet anyway: http://tds.loctite.com/tds5/docs/438-EN.PDF
Unread 04-08-2008, 16:58
R.C.'s Avatar
thanks a lot
R.C.
Unread 04-08-2008, 18:03
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
How thick are the wheels. The 4 lightening holes you have are not all that big. I would recommend that you either make them more useful by enlarging them or remove them and you could make the spokes smaller. Also do you plan on keying the shaft or using a sprocket with a bolt pattern?
Unread 05-08-2008, 00:29
The spoke design is a little inefficient. It makes no sense to widen the spoke as you go out, as the stress is greatest closer to the hub.
Depending on diameter and width, .68 is a tad heavy compared to a lot of custom wheels I have seen. What are it's dimensions?
Does look like a solid start though.
Also, if you are planning on mating it with a plate sprocket (I'm guessing by the hole pattern), you might want to do a 6 bolt hole pattern for #10's on 1.875 circle. This is AMs standard pattern, and will save you a lot of time if you use their sprockets.
I can't tell if it is supposed to be a live or dead axle. The center bore is too small for reasonable size bearings, but has no keyway.
Unread 05-08-2008, 16:21
Dowjonesbotics's Avatar
Dowjonesbotics Dowjonesbotics is offline
Leggooo
AKA: Jeremy Downes
FRC #1230 (Lehman Lionics)
Dowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the rough
yeah you attach treads with rivets
My account had been hacked and used by someone random for the past 2 years, my apologies for so many awful posts.
2011 New York City Regional Regional Finalist
2009 New York City Regional Team Spirit Award
2008 New York City Regional Team Spirit Award
2007 New York City Regional Team Spirit Award
2005 New York City Regional Champion
2003 New York City Regional Rookie All-Star
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
pic: Planetary...Wheel? Matt Krass Extra Discussion 23 27-06-2005 16:05
pic: da wheel CD47-Bot Robot Showcase 11 08-02-2004 22:04
2-wheel versus 4-wheel drive Ben Mitchell Technical Discussion 23 07-11-2003 00:50
