Go to Post Whether or not you use wheel weights, if you're running a wheel at several thousand RPM, you'd better have an effective containment system to protect the outside world in case something spontaneously disassembles itself. - Alan Anderson [more]
Unread 04-08-2008, 16:33
Dowjonesbotics's Avatar
Dowjonesbotics Dowjonesbotics is offline
Leggooo
AKA: Jeremy Downes
FRC #1230 (Lehman Lionics)
Dowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the rough
Re: pic: 6 wheel drive with a suspension
Originally Posted by joeweber View Post
Go to our site http://www.team1322.org/ideas.htm and scrol down to see a drawing of the suspention movement. The robot will be attached (with a pivot) to the drives in two places center of each moving drive.
Ohh, I see. Thanks.
That's seems like a very logical and feasible idea.
My account had been hacked and used by someone random for the past 2 years, my apologies for so many awful posts.
2011 New York City Regional Regional Finalist
2009 New York City Regional Team Spirit Award
2008 New York City Regional Team Spirit Award
2007 New York City Regional Team Spirit Award
2005 New York City Regional Champion
2003 New York City Regional Rookie All-Star
Unread 05-08-2008, 00:32
We have plans on using two omni wheels on both sides for the traction. Many have said how complex it is to build, but from the drawings that we have made there are only 5 parts that we have to make multiple times and the design for these parts are straight forward flat pieces with hole and slots. Very easy to C & C and only requires assembly. When we complete the drawings we will post them. The drawing that we have posted is only missing two parts but is pretty much completed. We will take that assembly and make four units and connect them at the omni wheel with an axel. To attach them to the robot we will have two steel tubes that a drive side will slide onto and then the bumper bolts will slide into the tube and two cotter pins will hold it all together. We have tried to make it simple so the student can understand what they are assembling and can make repairs when needed.
Complexity isn't just how many parts have to be made. You could use all COTS components and still have the most complex robot out there. This design is inherently more complex than a 6wd or a 4 wheel mecanum (the two most similar designs). Also, the pivoting frame throws a huge curveball when considering mounting manipulators.
pic: 6 Wheel drive Rh side WRGibbens Extra Discussion 5 19-01-2007 11:45
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
