Go to Post The practical experience that students learn by working with the mentors on a real life problem -- with real life constraints -- helps produce people who are good at those professions. - MechEng83 [more]
Unread 05-08-2008, 22:34
artdutra04's Avatar
VEX Robotics Engineer
Re: pic: 6 wheel drive with a suspension
Originally Posted by joeweber View Post
The reason we do not drive the wheels straight off the Bainbot shaft is to allow for straight driving. You know that the motors drive faster one direction than the other direction. Using them on helical gears the way we are make the motors go the same direction when the robot is going forward thus the motors are running at the same speed. So when we program for autonomous we will not have any problems with it pulling to the right or left.. Also note that when the robot goes sideways one set of motors will reverse so they will be going the same direction again allowing for straight travel.
Four encoders and a few dozen lines of code are a lot lighter and cheaper than four sets of helical gears.
Especially with our new processor, there should be no problems keeping up with all the data.
Art Dutra IV
世上无难事,只怕有心人.
Unread 05-08-2008, 22:38
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
Originally Posted by Alex.Norton View Post
One thing to note here. If your pivoting the "modules" about the steel tubes (that's my assumption) then whenever your suspension moves the distance between the steel tubes is going to change. Seem like it could be hard to mount other robot pieces on a dive base that keeps changing size.
One module is slotted, the length of the slot will detemin how far it can move. The distance is not far.
I can see why you might use the helical gears just to save space in the chassis but it would seem like the price wouldn't justify the cost. Although if you had some of the old helical gears from 2004 and previous season lying around I would definitively see the benefit.
We have some helical gears from 2004 but if the cost is too high we may have to change the set up. It would be nice to keep the space though.
Unread 06-08-2008, 08:55
GaryVoshol's Avatar
Cogito ergo arbitro
Originally Posted by Dowjonesbotics View Post
we used a drive train like that in class once
And what was your experience with it?
(since 2004)
Unread 07-08-2008, 00:49
RossK's Avatar
RossK RossK is offline
FRC #2741 (Method to Madness)
RossK is on a distinguished road
Send a message via AIM to RossK
i like this design a lot. Its very intuitive.
pic: 6 wheel drive with a suspension joeweber Extra Discussion 16 05-08-2008 00:32
pic: 6 Wheel drive Rh side WRGibbens Extra Discussion 5 19-01-2007 11:45
