Go to Post Insanity is overrated. - MissInformation [more]
Unread 08-08-2008, 15:34
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: pic: 6 wheel omni directional with a suspension
Perhaps I am misunderstanding the CAD model -- but how is it that the rods act as pivot points? My understanding was that each side pivoted about the omniwheel's axle. Your team's website corroborates that understanding.
Allowing one rod to slide in the mecanum wheel module serves to limit the travel of the suspension -- and any base mounted to would require similarly slotted mounting to remain in place.
This arrangement, however, does not allow for implementation of an independent suspension, as you'd mentioned in other threads, and is the source of my confusion.
If you were to approach a ramp at an angle, one mecanum wheel module would begin to climb and the opposite side, because it's connected by the steel rod, would follow suit -- losing contact with the ground. The vector addition that allows a mecanum drive to travel in a straight line is then lost and you will lose control of the machine.
--Madison--
...down at the Ozdust!
Unread 08-08-2008, 19:02
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
I will try to explain. View the picture at http://www.chiefdelphi.com/media/photos/31755 The base of the robot which will include any arm device and all other components will have the rest of the robot weight, will have two rods extending out of each side of the robot. One set of drives will slide over these two rods and be pined in place to allow for the pivot motion. One of the rods will slide into a hole of one drive and the other rod will slide into a slot (to allow for the small amount of back and fourth movement). If you lift one of the mecanum wheels that portion of the drive will pivot pushing down on the omni wheels (lifting the robot) and then the other portion of the drive will pivot and slide on the other rod (that is attached to the main part of the robot) and lift the other mecanum wheel. This action should be independent of the drives on the other side. This is very similar to the pathfinder robot on mars but not as elaborate. The amount of travel will only be the amount needed for the largest ramp. Movement can be controlled by a pneumatic connected at each omni and to the frame.
Unread 08-08-2008, 19:19
Madison's Avatar
FRC #0488 (Xbot)
When a pair of mecanum wheels drive toward one another, won't they first force the rod toward the other end of the slot, forcing one or both ends into the air and losing traction?
I'm trying to wrap my head around this. I still do not understand how a solid rod -- or a base that effectively acts as a solid rod -- can allow for, say, the front left wheel to go up a ramp while the front right remains level. The slotted end can handle this condition, but the fixed end cannot, as far as I can tell -- at least without expecting that the omniwheel can shift both upward and downward. In that case, I don't understand how you reasonably expect to know which direction the omniwheel will tend to shift.
--Madison--
Unread 08-08-2008, 19:31
joeweber's Avatar
Coach team 1322
No, the piviot at the omni will not allow theme to come together. Technicaly if the robot was very light and there was enough force from the drives you could lift the omni when the mecanum drive toward each other.
I placed a drawing on our news page to help with a visual. http://www.team1322.org/news.htm
pic: 6 wheel drive with a suspension joeweber Extra Discussion 18 07-08-2008 00:49
pic: 6 wheel drive with a suspension joeweber Extra Discussion 16 05-08-2008 00:32
pic: Holomonic (Bottom View) with Large Omni-Directional Wheel Kit nonother Extra Discussion 9 16-05-2007 00:26
pic: omni-directional hoverbot progress Tytus Gerrish Extra Discussion 11 08-01-2005 00:15
Omni Directional Wheels Will Seymour General Forum 3 11-01-2003 12:43
