Go to Post FIRST has given thousands of young people (like me) a head start in life because it teaches honesty, integrity, and an appreciation of other people's hard work. - Gabe [more]
Unread 10-08-2008, 18:46
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
pic: Top Down Gearbox View
Unread 10-08-2008, 18:49
run the trap!!!
Team Role: Human Player
Re: pic: Top Down Gearbox View
The face of those gears looks awfully narrow. You might get away with .25" face for the first gears, but the output gears really ought to be .375" or greater (especially for a direct drive).
At least give the gears thicker hubs.
-Philip J. Fry
Unread 10-08-2008, 19:01
RMS11's Avatar
Safety!!!!
AKA: Rick
Why? I was thinking that since since there are 3 reductions that each gear only takes 1/3 of the force.
2009 Palmetto Regional Champs
Unread 10-08-2008, 20:21
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
your thinking is a bit backwards.
The initial reduction will take the least amount of force, as there is the least amount of torque.
As you subsequently gear your transmission down, the torque of the motor becomes multiplied by the gear ratio of each stage of gearing.
2001-2004: Team 100
2006-Present: Team 254
Unread 10-08-2008, 21:25
RMS11's Avatar
Safety!!!!
AKA: Rick
So I should be more worried about gears slipping or shearing because of the thickness?
Unread 10-08-2008, 23:58
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
err, shearing, bending out to the side, and then grinding lots. Slipping is the least of your worries.
Each gear will take the full force because gears in gearboxes mesh in a series, not parallel.
I would definitely make them thicker. They are waay too thin.
What pitch are those by the way? I suggest not using anything too small. 20 dp is a good size, its what AM uses. If you need any help, my AIM's in my profile.
good luck, Vivek
EDIT: cory's absolutely right. you still don't want anything too thin. better too strong than too weak.
Unread 11-08-2008, 00:04
tennispro9911 tennispro9911 is offline
Alumni
AKA: Matt
FRC #2053 (TigerTronics)
tennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to behold
Send a message via AIM to tennispro9911
My advice is anytime your intuition tells you something, double check it with physics. That's something that's served me well is to both trust my gut, but make sure my gut is correct, and make sure someone else confirms that if I am designing something critical to my robot's success such as a gearbox. Also, don't view criticism as negative, but rather that all of the people on CD want to make sure that come competition, everyone has a working robot.
2053 Alumni
Unread 11-08-2008, 00:33
Cory's Avatar
AKA: Cory McBride
You'd probably run into problems with teeth shearing off.
3/8" face width 20 DP is generally the defacto gear type for FRC drivetrains.
Depending on the type of load you'll be seeing, you can increase DP or reduce face width in earlier stages. In output stages you probably don't want to go less than 3/8" face width and 20 DP.
Again, there is math that will verify these rough guesses, but that's a bit more complicated.
2001-2004: Team 100
Unread 11-08-2008, 08:27
RMS11's Avatar
Safety!!!!
AKA: Rick
Is there a place you would recommend gears with 3/8 face and 20 pitch? We normally buy from wm berg because of their great selection of gears but they only come 1/8 thick. We could though double them up, but that gets to be like 40 or for 3/8 60 dollars per gear... Thanks
Unread 11-08-2008, 10:08
vivek16's Avatar
AKA: vivek
www.andymark.biz
They even come prebroached.
-Vivek
Unread 11-08-2008, 10:49
M. Mellott's Avatar
CAD God
AKA: Mike Mellott
You can get them from McMasterCarr, or go to one of the primary manufacturers at Martin Sprocket & Gear, Inc.
Unread 13-08-2008, 15:45
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
233 has always used 32 pitch for the first stage of our gearboxes. We have even used 1/8" face width with no problems. The second and if necessary third stage is usually 24 pitch. We have used 20 pitch gears if we cant find the ratio we need in 24 pitch. All our gears use the 20 degree pressure angle.
mike d
See Ya
pic: Virginia's DREAM top view falconmaster Extra Discussion 7 25-01-2008 18:49
pic: Top view Cheesed robot falconmaster Extra Discussion 4 18-01-2008 12:03
pic: A View From the Top CMB Extra Discussion 2 10-01-2007 22:21
pic: Top View of Shaft Drive MAteo9944 Extra Discussion 2 30-12-2006 20:59
pic: Team #910 Top View CD47-Bot Extra Discussion 7 06-03-2003 12:41
