Go to Post I said it was called FIRST Robotics and the coolest thing I'd seen that day was a 150lb robot balance with another one on a teeter-tooter and and then score basketballs from 30 feet away. - Siri [more]
Unread 10-08-2008, 22:27
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
pic: gearbox open, geared down 10:1
Unread 10-08-2008, 22:28
KF987 KF987 is offline
AKA: Keaton
FRC #2034 (IncrediBULLS)
KF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud of
Send a message via AIM to KF987
Re: pic: gearbox open, geared down 10:1
Is this for two globe motors? Looks similar too what we almost used for our arm this year but ended up going with worm gears. Same reduction i think as well...
Keaton
Unread 10-08-2008, 23:31
artdutra04's Avatar
VEX Robotics Engineer
Is there any particular reason why you chose to do the reduction in three stages?
If you are looking to build a custom transmission with an end ratio of about 10:1, you can use COTS gears from AndyMark with only two stages using a 50:14 (3.571:1) reduction in the first stage and a 40:14 (2.857:1) reduction in the second stage, for an overall reduction of 10.202:1. And if you have access to a milling machine or lathe, it isn't very difficult to lighten these gears with pockets and/or holes drilled through them.
Art Dutra IV
世上无难事,只怕有心人.
Unread 11-08-2008, 02:33
I agree with Art. You can greatly improve the design (and make it easier to manufacture) by switching to the AndyMark Gears.
Unread 11-08-2008, 08:44
RMS11's Avatar
Safety!!!!
AKA: Rick
Ya there was a reason, and it appears it was a wrong reason so I am probably going to switch it around. I usually use wmberg, their gears are expensive but their choices are great ant they are ammazingly precise.
2009 Palmetto Regional Champs
pic: Top Down Gearbox View RMS11 Extra Discussion 11 13-08-2008 15:45
pic: A N.E.R.D. down south dk5sm5luigi Extra Discussion 4 15-07-2008 01:45
Offseason gearbox project... maybe this gearbox has helical gears? Travis Covington Technical Discussion 17 05-06-2006 11:48
pic: Man down, man down! Alex Cormier Extra Discussion 3 19-04-2006 15:27
We geared this one really fast, so fast it caught on fire! Travis Covington Robot Showcase 18 12-02-2005 07:22
