pic: Good overall view
Re: pic: Good overall view
I designed this 6WD in solidworks over the past few days. Most gears are just circles and stuff. Right now it weighs a bit over 20 pounds without the CIM's and chain with banebots 4 7/8 inch wheels or 24 pounds with custom aluminum wheels. Both sides are identicle and can be removed by pulling 4 easy to access cotter pins for changing out sides on the fly if needed. Please leave feedback. Go WiredCats
and check out other pics. |
Love the Cad and what is the thickness/material on that back panel "WiredCats 2415". Also on the middle beams that have that CNC pattern, you can save a lot of weight by CNCing the top and bottom of it too. You won't lose too much, it will still be sturdy.
The back panel could be a 1/16 of an inch, that's only if you want to.
If i remember right, the pink team used a 16th inch CNC cutout of 6061 for their back. They said it worked fine and never had to replace it. The key thing is, that it will be protected by bumpers.
I would recommend changing the C channel of the cross supports to rectangular/square tubing. The Significant increase in strength is worth the minor weight increase.
As for the back panel, 1/8" or 1/16" will be both be bent very easily if not covered by bumpers in the current setup. If they are covered correctly by bumpers that are well supported, neither would be an issue. As for cutting the name and number into it, those letters are big, and will reduce the strength a good deal. Since it'll be covered by bumpers, really no reason to write that. |
For that outer plate, if you really want to do it, I would use some C channel or box tubing instead. Just going to 1/4" plate would be rather inefficient. Using C channel how 488 did on this base is a much stronger option than just using plate. Once again I would prefer box tubing for the extra rigidity, but that's just me. As for the gearing, you'll find that the cost of AndyMark gears is very nice (same for their quality). The 14T pinion for the CIM motors The 40T gear The 14T gear with a hex bore The 50T gear You can probably even find a way to use AndyMarks various shafts (from their gearboxes) to eliminate even more custom parts from the design. |
#11
You could probably pull off that 10-1 reduction gearbox with 2 globe motors by putting these hub things on the shafts of the globes, using these gears on those hubs, driving a 50 tooth gear with that, having a 14 tooth gear on the same shaft as that 50 tooth gear, and then having a 50 tooth output gear. That would be a 10.5:1 reduction. You could swap that output gear for a 48 to get a 10.1:1 reduction. -Vivek |
#12
We did use 1/16" aluminum for our back and front, we never replaced it, but, it was supported by 2 pieces of angle attaching it to the bottom plate, riveted at the ends of 4x4, and at the top had a piece of 2x1 tubing supporting it.
| Overall electric help | Aces | Electrical | 6 | 12-01-2007 20:16 |
| Overall Rankings | sgsdragons | Championship Event | 2 | 24-04-2005 22:58 |
| Best OVERALL drive team | Kyle Love | Chit-Chat | 8 | 15-04-2005 05:08 |
| Good news for those who liked the old threaded view | Brandon Martus | Announcements | 6 | 24-11-2001 21:22 |
