Go to Post I would like to extend my deepest, most sincere thanks to the GDC, for bringing alliances to us in 1999. - Ken Patton [more]
Unread 11-08-2008, 17:54
artdutra04's Avatar
VEX Robotics Engineer
Re: pic: 6WD Riveted Frame Development
As long as you use enough of them, rivets work just fine for holding frames together, especially since you also have the top and bottom gusset plates. For some of the more high strength areas, you may want to stick with 3/16" steel rivets (such as where the front/rear frame members intersect with the longitudinal drive train members), but for things like the top and bottom gusset plates, 1/8" steel rivets work just fine.
Unless you need something to be removable, use rivets if at all possible. It makes it so much easier when you don't have to figure out how to get a wrench into the chassis to tighten nuts. ;-)
Otherwise, this definitely looks like a good chassis and drive train design so far.
Art Dutra IV
世上无难事,只怕有心人.
pic: 1760 - 6WD with OMNI wheels Mark Pendergast Extra Discussion 1 20-03-2008 19:35
pic: Frame is falconmaster Extra Discussion 1 17-01-2008 23:11
pic: 6WD Design Iteration Madison Extra Discussion 7 01-01-2008 14:00
pic: Isometric View of A 6WD module Cody Carey Extra Discussion 8 04-01-2007 17:19
