Go to Post Most of the people who fit the profile of long tenured FIRST mentor are either already on a team or locked up in an institution where they belong... - PayneTrain [more]
Unread 12-08-2008, 02:03
M. Mellott's Avatar
CAD God
AKA: Mike Mellott
Re: pic: 6WD Riveted Frame Development
Originally Posted by squirrel View Post
1726 did a riveted chassis this year, made from 1 x 4 x 1/4" pultruded fiberglass channel, and .060" sheet 3003 aluminum for the full belly pan and top gussets. We used 3/16" rivets from the hardware store. It worked just fine. Also we used cantilevered axles, mounted directly to the fiberglass, and had no problem with them. There was quite a bit of design work in this chassis, so fabrication and assembly was straightforward.
I think there are some pictures on the NERDS photo gallery...
I took a look at the pictures and noticed you notched the U-channel to insert the end into the end rail similar to this design. However, there appeared to be nothing joining the four fiberglass frame members together except for the bellypan and the four sheetmetal gusset plates on top of the four corners, with nothing actually inside the corners. Is that correct?
pic: 1760 - 6WD with OMNI wheels Mark Pendergast Extra Discussion 1 20-03-2008 19:35
pic: Frame is falconmaster Extra Discussion 1 17-01-2008 23:11
pic: 6WD Design Iteration Madison Extra Discussion 7 01-01-2008 14:00
pic: Isometric View of A 6WD module Cody Carey Extra Discussion 8 04-01-2007 17:19
