Go to Post 90% of innovation is inspiration. - martin417 [more]
Unread 12-08-2008, 08:50
MrForbes MrForbes is online now
Re: pic: 6WD Riveted Frame Development
In the design M. Mellott posted, it appears that the attachment at the web of the channel is probably not necessary, since most of the web between the wheel and the end of the frame has been cut away. Also the bending load is highest at the flange of the channel.
I'd suggest not cutting out the side frame members for lightening...leave them strong, and you should be able to eliminate the corner pieces that connect the webs of the channels, while enlarging the top and bottom gussets so that they make good-sized triangles.
pic: 1760 - 6WD with OMNI wheels Mark Pendergast Extra Discussion 1 20-03-2008 19:35
pic: Frame is falconmaster Extra Discussion 1 17-01-2008 23:11
pic: 6WD Design Iteration Madison Extra Discussion 7 01-01-2008 14:00
pic: Isometric View of A 6WD module Cody Carey Extra Discussion 8 04-01-2007 17:19
