Go to Post I've never liked the pressure pads. This just confirms my suspicions: Pressure pads hate robots. It must be some inferiority complex or something. - Andy A. [more]
Unread 17-08-2008, 18:40
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
pic: 5 Inch Wheel
Unread 17-08-2008, 19:28
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: pic: 5 Inch Wheel
The first thing I see missing is no key or bolt pattern for a sprocket.
Unread 17-08-2008, 19:42
RMS11's Avatar
Safety!!!!
AKA: Rick
Ya, I didnt include a keyway but I plan to key this once we make it, if it ever gets made. Can you make keyways on a mill? I dont think you canm but might be wrong...
2009 Palmetto Regional Champs
Unread 17-08-2008, 19:49
gblake's Avatar
gblake gblake is online now
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
The spokes look nice; but I'm curious if there is any mathematical basis (or any other basis other than artistry) for their shape?
FYI - I have no hidden agenda or Socratic teaching attempt hidden in my question - I am certainly not good enough at mechanical engineering to perform anything other than the grossest levels of analysis to answer a question like the one I just posed.
Instead, each time I see a design like this one posted as a CAD rendering, I am sincerely curious what design guidelines, or computational analysis, or empirical data the author was able to use when creating the design. Yours just happens to be the one that finally got me to ask the question.
What can you tell us?
Blake
Unread 17-08-2008, 20:17
RMS11's Avatar
Safety!!!!
AKA: Rick
I first cut out 5 spokes that went fully from the center to the outside with all inside material cut out. I made them 1/4 inch because I felt that to be plenty to support the wheel. I filletted the edges of the spokes for extra support and thev used cosmosxpress in solidworks to run stress analysis, placing an 120 lb force on an individual wheel supported by the axle. Then after seeing it would not break I cut more weight by adding holes in an artsy way and did more stress analysis. Really I find the best way to make light weight objects is to cut a little weight and then stress test and repete until you are either happy with the weight or unhappy with how strong it is getting.
Unread 17-08-2008, 20:35
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
personally i would favor a broached hex to the keyway for strength
mike d
See Ya
Unread 17-08-2008, 20:37
The spoke design is currently inefficient. The force exerted on the spoke via the torque applied at the hub decreases as you get farther away from the hub. So, the spokes should be thicker towards the center and thinner as you get closer to the rim. The holes in the spokes also greatly decrease the strength, If the spokes are strong enough as is with the holes, then I would redo do it with smaller spokes without holes (which if done right would weigh less than the current spoke).
But, overall, a solid start on a wheel design.
Unread 17-08-2008, 20:52
RMS11's Avatar
Safety!!!!
AKA: Rick
Why does torque decrease as you get farther away?
Unread 17-08-2008, 21:00
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
The torque is mainly at the shaft or the middle of the wheel. As you move farther from the center, the torque decreases.
R.C.
MadTown Robotics Team 1323
Unread 17-08-2008, 21:02
The torque doesn't change at all, but if you pick a cross section of the spoke, you can say the force on it (from the torque) is the torque divided by how far it is from the center. Think of it as a lever arm, if you apply a torque to the end of it, the force the end of the lever exerts decreases as the lever's length is increased.
And for what Mike says, YES!!!! If you can find a way to use hex axles, do it. They form a stronger connection than a keyed shaft, and are just way easier to work with... On top of that you never have to worry about losing a key, or making them in the first place.
Unread 17-08-2008, 21:07
RMS11's Avatar
Safety!!!!
AKA: Rick
Thanks We might go with hex. Is it hard to find hex sprockets and what do you use as bearings with a hex shaft?
Unread 17-08-2008, 21:13
all hail Passmore
pink uses flanged bearings and hex stock from mcmaster carr.
you can put the hex stock in a lathe and turn it under size so the bearing slips on and the remaining hex locates it from side to side
mike d
See Ya
Unread 17-08-2008, 21:14
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
As Adam said, the force (not the torque) on the spoke decreases as you get farther from the center.
Torque = Force x Distance, so as distance increases, force decreases.
Edit: Beat to it.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 17-08-2008, 21:15
Team 2021 Captain
AKA: Chris Davidson
Take the hex shaft to a lathe and turn it down to a circle that will fit into a bearing.
EDIT: Mike beat me.
Unread 17-08-2008, 21:18
RMS11's Avatar
Safety!!!!
AKA: Rick
EDIT: Mike beat me.
Ya thats our problem, we have a mill but no lathe. We could do it, but it is a huge hassle and we wouldnt have the freedom of doing this in shop... Hopefully we will get one sometime...
4 inch wheels R.C. Technical Discussion 13 12-06-2008 17:58
Going over 6 inch step with 12 inch wheels Joe P Technical Discussion 25 12-04-2004 11:15
12 Inch Wheel Available in Several Formats Ed Sparks Inventor 1 19-01-2004 07:12
pic: 6 and 12 inch platform rise CD47-Bot Extra Discussion 2 18-01-2004 09:15
