Re: pic: Floating Zip Tie Chain Tensioner
Also another question, would teams buy this if they were available???
Yes, especially if offered in multiple sizes. We've had some issues with our homebuilt non-floating tensioners over the years, and never had enough money to spare for several McMaster-style tensioners.
What sizes would you want? Currently we have:
1.25 x 2.5 |
I meant for different chain sizes. #25, #35.
They work for either one, just like mcmasters.
This is a fantastic and simple idea! Now let's hope they don't ban zip ties... We would want #25 chains, but probably only 1.25" in length because we have some short chain runs to deal with from the transmissions.
Have you done any efficiency experiments, e.g. how much efficiency is lost due to these tensioners when compared other methods? Examples include autotensioning (sliding a wheel out like 254/968/etc), simple rotary tensioners that use delrin or similar plastics, or the old adjustable bolt/sprocket method. If you find that there's more loss (due to increased contact surfact area) you could experiment with teflon or oil-impregnated plastic surfaces. Also, you could change the geometry in the channel itself to be curved convex rather than simply flat. This is how the secondary tensioners on Harley Davidson motorcycles work -- turn a bolt and a convex-curved piece of teflon raises against the chain to fine-tune the tension. < edit > Another thing you could do is create a working relationship with a company such as AndyMark or a local plastics mold company, who can mass-produce these for teams and give your team a % of the revenue. The upside to this is that it should be low-stress supplemental revenue for your team. The downside to this is that you miss producing and selling these yourselves, which opens up a whole new can of worms in opportunities for more people from your community to learn and participate in your program. Food for thought. < /edit > Last edited by JesseK : 18-08-2008 at 09:19. |
It depends on your price point. Unfortunately, with something this small and this easy to make, your labor (or mill time) is going to KILL you on pricing. Now, if you could get a plastics shop to start cranking them out by the thousands off a small injection mold so that you could sell them for a couple of bucks for a pair... well... I'll tell you one team that would be interested! Get in touch with AndyMark. I'm sure they go through this all the time and can help you out. Incredible idea! |
An interesting design, and an interesting discussion on IP. (Intellectual Property... patents, copyright, etc.) The CD community does a pretty good job of giving solid information on the challenges and benefits of patents, and dispels some common myths such as the protection offered to engineering designs through copyright.
It looks like these could be mass produced fairly easily on a table saw with some fairly simple jigs. There are also some alternatives to UHMW that are worth considering. A local firm (North Vancouver, BC) produces a graphite/epoxy composite for lubricating the side of train wheels. This is an extremely hard-wearing, low-friction compound that can easily be shaped with wood-working tools, but has the added benefit of lubricating the chain (or wheels) as it slowly wears away. They gave us some and we used this to tension our chains three years ago, with a grooved sliding tensioner that was adjusted cam-style on just one side of the chain. It worked great. But I've lost their contact information, sorry. As far as the profitability of marketing this design, the tensioners would end up being a fairly low cost item (the raw materials are commonly available and the machining steps relatively simple) so it would require a significant volume of sales to generate a large amount of revenue, and, as mentioned several times, a large amount of revenue is required to justify the cost of a patent. However it is possible to file for a provisional patent at a much reduced cost ($500 is the ballpark figure that runs through my head), and while that only protects your design for a year, that may be enough time to test market it and/or license the design to someone who is willing to pay the costs of obtaining a full patent. Whether or not this is a patentable or profitable design, it is a good one and one to be proud of. It may well be worth the effort of doing a patent search (google patents and freepatentsonline.com help the individual inventor get a start) as well as a search of the web for similar designs. (Remember that what matters is that you were first to invent, not first to patent. Even if you were to get a patent, if someone were to demonstrate that the device had been invented 50 years ago they could have your patent overturned... regardless of whether the original inventor had filed for a patent or not. There is a whole section of patent law on the issue of "first to file" vs. "first to invent", but your main concern here is to look for "prior art"... ie. has anyone done this before?) It may also be worth going through the exercise of setting up a small-scale production run, developing a brand name for your product, and marketing your product just as an educational exercise. If it turns a profit... great! Jason P.S. Also remember that a patent doesn't prevent someone from using your idea... it merely gives you the right to sue them for damages if they do... and a US patent only protects ideas in the USA. If a US patent is expensive, then protecting your idea world-wide is phenomonally expensive (any idea what it costs to get a patent translated in to Japanese?) That doesn't mean don't "go for it" if you want the experience... in many ways the educational value of developing your design is likely to be far, far greater than the commercial value... just as the educational value of building a FIRST robot is far, far greater than any commercial applications the robots might have. P.P.S. Should you decide to patent in Canada, I can introduce you to some excellent Canadian patent agents who know a thing or two about FIRST. Last edited by dtengineering : 18-08-2008 at 13:40. |
#10
From a patenting point of view it is also extremely helpful to know exactly what the "prior art" is so that you can describe precisely how a design differs from the prior art and what benefits your design offers. Perhaps this design is simpler to produce, is more reliable, uses less expensive materials, or is easier to adjust. If you don't know about prior art, and sufficiently differentiate your product from what has come before, you may spent a whole lot of time and money getting a patent only to discover that you can't enforce it due to the prior art... so knowing that there are similar designs out there in the public domain is useful for the inventor. It is extremely difficult to come up with a revolutionary mechanical design. After centuries of designing developments tend to be evolutionary rather than completely new. Often those incremental improvements are quite profitable and quite worth patenting, even though they may only improve performance in some small way. I can see how this design offers some incremental improvements over what I've seen before... and the suggestion to use a hose clamp is possibly another incremental improvement. Given that the discussion of patents, in the absence of a business plan, is purely academic, knowing that there have been similar desgins in no way marginalizes the "great idea" factor for the designer. So rather than viewing your comments as a downer, I'd view them as evidence that this design is on the right track! Jason |
#12
I know you're in discussions, so I won't comment specifically on that. One option is to simply give them the idea for free (or some minor consideration, like a 20% discount on your next order). But, that depends on whether they 'want' something like that, or think it will sell. They have some small risk in the cost of manufacturing and inventory, but the risk is small only because the cost is low. Another alternative is to ask AndyMark to market the product, and you simply supply it. They have little upfront expenses, aside from a web page on their site. You have a small expense, making several samples and a small stock for them to hold on to for orders. And you can make a few dollars for the team, or for yourself. Just beware that if a LOT of teams want these, you may need to buy materials and make hundreds or even thousands* of them in just a few days - during build season. Getting a whole team to help - who gets the money? - might ease this worry. I'm not meaning to suggest that AndyMark will do this, I'm just using their name as an example. *We can only hope! Don |
#14
Oh, heck... here's someone who's written it up better and more authoritatively than I http://www.lawmart.com/searches/difference.htm That is the value of a patent... it truly protects the idea of the design, which is the fundamental part of the invention rather than just an expression of the idea. Jason P.S. Good luck with manufacturing and marketing your design. It looks like a design that is extremely well-suited to mass production and once you get your jigs worked out you should be able to churn them out by the hundreds fairly quickly. Last edited by dtengineering : 18-08-2008 at 22:23. |
#15
Think about how many of these you need to make, how quickly each one needs to be made, and how much you need to sell them for to break even. Then think about how many you think you can possibly sell. If you do the math, I don't think it's a viable investment to try to mass produce these, or even make them on a fairly large scale. To actually make money you need to be injection molding, not milling these. Injection molding is orders of magnitude more expensive than even the most generous estimate of demand for these. Given demand, and cost of contracting these out to a machine shop, or time involved in making them yourself, I don't think you can come out on top. Especially given that anyone with a manual mill or even drill press with x+y table can make one of these in about 15 minutes. Keep in mind that if you choose to make them or have someone else machine them, you have to be able to meet the criteria of a vendor, as well as be capable to potentially ship one to every team in FIRST, if they ordered one, within x time period (I think 5-7 days? can't recall). |
| Flexible Floating Idler Tensioner | AndyB | Technical Discussion | 23 | 22-07-2008 11:05 |
| pic: Kitbot Chain Tensioner 2 | Donut | Extra Discussion | 13 | 10-12-2007 15:57 |
| pic: Kitbot Chain Tensioner 1 | Donut | Extra Discussion | 6 | 21-12-2006 00:43 |
| Chain tensioner usage | Rhs953 | Kit & Additional Hardware | 3 | 10-02-2004 17:04 |
| Chain Tensioner? | Gabriel | Technical Discussion | 14 | 29-01-2004 09:16 |
