Go to Post When faced with large problems, I always see it as an opportunity to dream big. Really big. - JaneYoung [more]
Unread 18-08-2008, 09:08
JesseK JesseK is online now
Re: pic: Floating Zip Tie Chain Tensioner
This is a fantastic and simple idea! Now let's hope they don't ban zip ties... We would want #25 chains, but probably only 1.25" in length because we have some short chain runs to deal with from the transmissions.
Have you done any efficiency experiments, e.g. how much efficiency is lost due to these tensioners when compared other methods? Examples include autotensioning (sliding a wheel out like 254/968/etc), simple rotary tensioners that use delrin or similar plastics, or the old adjustable bolt/sprocket method.
If you find that there's more loss (due to increased contact surfact area) you could experiment with teflon or oil-impregnated plastic surfaces. Also, you could change the geometry in the channel itself to be curved convex rather than simply flat. This is how the secondary tensioners on Harley Davidson motorcycles work -- turn a bolt and a convex-curved piece of teflon raises against the chain to fine-tune the tension.
< edit >
Another thing you could do is create a working relationship with a company such as AndyMark or a local plastics mold company, who can mass-produce these for teams and give your team a % of the revenue. The upside to this is that it should be low-stress supplemental revenue for your team. The downside to this is that you miss producing and selling these yourselves, which opens up a whole new can of worms in opportunities for more people from your community to learn and participate in your program.
Food for thought.
< /edit >
GitHub
Unread 18-08-2008, 11:33
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I can't speak for specifically how much loss there is between different types, but the method of sliding the wheel is going to be by far the most efficient, as it's the only style of tensioning that does not touch the chain and add more friction to the system.
2001-2004: Team 100
2006-Present: Team 254
Flexible Floating Idler Tensioner AndyB Technical Discussion 23 22-07-2008 11:05
pic: Kitbot Chain Tensioner 2 Donut Extra Discussion 13 10-12-2007 15:57
pic: Kitbot Chain Tensioner 1 Donut Extra Discussion 6 21-12-2006 00:43
Chain tensioner usage Rhs953 Kit & Additional Hardware 3 10-02-2004 17:04
Chain Tensioner? Gabriel Technical Discussion 14 29-01-2004 09:16
