Go to Post Typed in "WaTeRgAmE" for the password and unfortunately it wasn't it. Bummer. - Kuhnahtt [more]
Unread 18-08-2008, 11:58
Tazlikesrobots's Avatar
Tazlikesrobots Tazlikesrobots is offline
Jack of all trades...Master of none
AKA: Robert
FRC #1745 (P-51 Mustangs)
Tazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud ofTazlikesrobots has much to be proud of
Send a message via Yahoo to Tazlikesrobots
Re: pic: Omnibot
We used a design very similar to yours this year and it worked very well for us! Our chassis was square shaped and the wheels were placed as close to the edge as possible.
It is all mind over matter....If you don't mind, it does not matter.
_________________
2006 Woodie Flowers Award Recipient - Lone Star Regional
2006 Rookie All-Star - Lone Star Regional
2007 Lone Star Regional Champions
2008 Quarter-finalist - Lone Star Regional
2009 Chairman's Award & Website Award - Dallas Regional
2009 Quarter-finalist - Dallas Regional
2010 - Xerox Creativity Award & Semi-finalist - Dallas Regional
Unread 18-08-2008, 12:22
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Re: pic: Omnibot
You will most likely be pushed around alot with your current design (this is from my personal experiance). But omni's mounted to and prependicular to the direction of movement could spell trouble.
Also you don't need to mount your wheel in a perfect square, if you mount what I'm guessing is your forward and rear omni futher back you will increase stabbility. Just make sure your wheel that are found on the same axis (left and right, forward, and, rear) are mounted so that they lie on the same circle. If your really good you should be able to make both of your circles have the same center point (and center point of robot), but good luck...
Is now an engineer thanks to FIRST.
Unread 22-08-2008, 19:46
gimpnub gimpnub is offline
Xtreme Heat Xtraordinaire
AKA: Curley
FRC #0223 (Xtreme Heat)
gimpnub has a spectacular aura aboutgimpnub has a spectacular aura aboutgimpnub has a spectacular aura about
Re: pic: Omnibot
why don't you use a three-wheel setup instead of a four-wheel setup?
correct me if i'm wrong but i think it would give you more stability and reduce your weight at the same time
your only difficulty might be programming it with 0, 60, and 120 degrees instead of 0, 90, 180, and 270 degrees, but there are also less wheels to program
i don't know how speed would be affected by the 3-wheel setup
if i'm wrong in any areas please forgive me and ignore my comments
Unread 22-08-2008, 20:12
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
Re: pic: Omnibot
The main advantage of four-wheel omni that I can think of is power. Even with vectors doing crazy things to the power output, 4 motors is stronger than 3.
Unread 22-08-2008, 22:52
Protronie's Avatar
Protronie Protronie is offline
Have big wrench...and will use it!
Protronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud of
Send a message via ICQ to Protronie Send a message via Yahoo to Protronie
Re: pic: Omnibot
Very interesting... is this something that going to be built or just a design exercise ?
-p
Protronie rule 5 - When the big wrench starts swinging, get out of the way!
Unread 23-08-2008, 01:49
kajeevan kajeevan is offline
FRC #0188 (blizzard)
kajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud of
Re: pic: Omnibot
Right now its just a design but who knows I may just get to build one.
Unread 22-08-2008, 23:11
EricH EricH is offline
Re: pic: Omnibot
Reduce weight, yes, but 3-wheel setups have to be carefully thought out. I can only think of 4 off the top of my head: 330 (2002) had a triangular robot and no omnis; 67 (2005) had a peculiar triangular setup that I don't quite remember, but it involved flopping down; 16 (2006) had a 3-wheel swerve with pads to keep the frame from hitting the carpet and digging in, and 148 (2008) had a 3-wheel swerve patterned off of 118's V6 and a much smaller robot than the other three. The only one of those that involved omnis was 67's, IIRC. I remember hearing that 67's drive code took up an awful lot of room on their controller...
More stability is debatable. If you've got it fully in a square or circle, possibly. But with a frame like this, I don't think so. You've got a big risk that one corner will go down and dig into the carpet.
Speed might not be affected. I'd have to do the vectors to figure that out, and I'm not in a position to do that right now...
Unread 23-08-2008, 00:18
Aren_Hill's Avatar
Build Nifty Things
Re: pic: Omnibot
Im almost completely positive 67 in 2005 was a 3 wheel swerve with no omni's involved.
you can see the front two wheels here : http://www.chiefdelphi.com/media/photos/20772
A guy who likes robots.
Unread 25-08-2008, 01:22
Re: pic: Omnibot
I'm pretty sure it was a kiwi-type system, like below. I tried to search, but no luck yet.
Unread 25-08-2008, 01:27
Re: pic: Omnibot
Nope, sorry Eric, but 67 definitely had a 3 wheeled crab in 2005.
Unread 25-08-2008, 01:31
Re: pic: Omnibot
Actually, I found a picture... of 67 2005... in a match... on two wheels, showing the third. NOT a true swerve. Swerve, yes. Three wheeled robot, yes. But not a three-wheel swerve. One wheel steered, three drove. Zoom in on the picture. One wheel is turned; the others appear not to be able to.
Unread 25-08-2008, 01:39
Re: pic: Omnibot
Actually, I found a picture... of 67 in 2005...during build... on the ground, showing all three wheels. A true swerve, with all three wheels able to rotate.
No hard feelings eric
Unread 25-08-2008, 14:16
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Re: pic: Omnibot
If you move the wheels to opposite corners the math will work out exactly the same as it would for the configuration shown.
There are two advantages that a holonomic base built using this configuration has over a swerve drive:
1) The modules are lighter and less complex.
2) The robot can translate and rotate at the same time (I've seen this called "frisbee motion")
The programming is more complex, but there are plenty of examples available to get you started.
Unread 25-08-2008, 23:22
Re: pic: Omnibot
And rotate independently... No wonder the code took so much space in the controller.
Back on topic: If you're going to do 3WD, plan it out first. Carefully. As noted, only one robot (to our knowledge) has had a 3WD omni system; most of the other 3WDs were crab/swerve systems.
Unread 25-08-2008, 23:30
Data Nerd
FRC #0079
Re: pic: Omnibot
Also, the one robot that did a 3 wheeled omni (857) didn't use code to control their wheels, they used hardware (http://www.chiefdelphi.com/media/photos/16410) Dont forget that sometimes that solution works better than complex code. No reason to make the code more complex than it needs to be. Could it be done in code? Yes, is complex code always better? That is up to you.
pic: Omnibot Ryan M. Extra Discussion 18 03-08-2005 08:19
