Thread Tools |
Rating:
Display Modes |
Re: pic: Omnibot
You will most likely be pushed around alot with your current design (this is from my personal experiance). But omni's mounted to and prependicular to the direction of movement could spell trouble.
Also you don't need to mount your wheel in a perfect square, if you mount what I'm guessing is your forward and rear omni futher back you will increase stabbility. Just make sure your wheel that are found on the same axis (left and right, forward, and, rear) are mounted so that they lie on the same circle. If your really good you should be able to make both of your circles have the same center point (and center point of robot), but good luck... Last edited by XXShadowXX : 18-08-2008 at 12:30. |
Re: pic: Omnibot
why don't you use a three-wheel setup instead of a four-wheel setup?
correct me if i'm wrong but i think it would give you more stability and reduce your weight at the same time your only difficulty might be programming it with 0, 60, and 120 degrees instead of 0, 90, 180, and 270 degrees, but there are also less wheels to program i don't know how speed would be affected by the 3-wheel setup if i'm wrong in any areas please forgive me and ignore my comments |
Re: pic: Omnibot
The main advantage of four-wheel omni that I can think of is power. Even with vectors doing crazy things to the power output, 4 motors is stronger than 3.
Re: pic: Omnibot
Very interesting... is this something that going to be built or just a design exercise ?
-p ![]() |
Re: pic: Omnibot
Right now its just a design but who knows I may just get to build one.
Re: pic: Omnibot
More stability is debatable. If you've got it fully in a square or circle, possibly. But with a frame like this, I don't think so. You've got a big risk that one corner will go down and dig into the carpet. Speed might not be affected. I'd have to do the vectors to figure that out, and I'm not in a position to do that right now... |
Re: pic: Omnibot
you can see the front two wheels here : http://www.chiefdelphi.com/media/photos/20772 |
Re: pic: Omnibot
Re: pic: Omnibot
Nope, sorry Eric, but 67 definitely had a 3 wheeled crab in 2005.
#10
Re: pic: Omnibot
Re: pic: Omnibot
Actually, I found a picture... of 67 in 2005...during build... on the ground, showing all three wheels. A true swerve, with all three wheels able to rotate.No hard feelings eric ![]() |
#12
Re: pic: Omnibot
If you move the wheels to opposite corners the math will work out exactly the same as it would for the configuration shown.
There are two advantages that a holonomic base built using this configuration has over a swerve drive: 1) The modules are lighter and less complex. 2) The robot can translate and rotate at the same time (I've seen this called "frisbee motion") The programming is more complex, but there are plenty of examples available to get you started. |
#13
Re: pic: Omnibot
Back on topic: If you're going to do 3WD, plan it out first. Carefully. As noted, only one robot (to our knowledge) has had a 3WD omni system; most of the other 3WDs were crab/swerve systems. |
#14
Re: pic: Omnibot
Re: pic: Omnibot
Cooool, are those the robots that spin really really fast??
| pic: Omnibot | Ryan M. | Extra Discussion | 18 | 03-08-2005 08:19 |
