Re: pic: Floating Zip Tie Chain Tensioner
An interesting design, and an interesting discussion on IP. (Intellectual Property... patents, copyright, etc.) The CD community does a pretty good job of giving solid information on the challenges and benefits of patents, and dispels some common myths such as the protection offered to engineering designs through copyright.
It looks like these could be mass produced fairly easily on a table saw with some fairly simple jigs. There are also some alternatives to UHMW that are worth considering. A local firm (North Vancouver, BC) produces a graphite/epoxy composite for lubricating the side of train wheels. This is an extremely hard-wearing, low-friction compound that can easily be shaped with wood-working tools, but has the added benefit of lubricating the chain (or wheels) as it slowly wears away. They gave us some and we used this to tension our chains three years ago, with a grooved sliding tensioner that was adjusted cam-style on just one side of the chain. It worked great. But I've lost their contact information, sorry. As far as the profitability of marketing this design, the tensioners would end up being a fairly low cost item (the raw materials are commonly available and the machining steps relatively simple) so it would require a significant volume of sales to generate a large amount of revenue, and, as mentioned several times, a large amount of revenue is required to justify the cost of a patent. However it is possible to file for a provisional patent at a much reduced cost ($500 is the ballpark figure that runs through my head), and while that only protects your design for a year, that may be enough time to test market it and/or license the design to someone who is willing to pay the costs of obtaining a full patent. Whether or not this is a patentable or profitable design, it is a good one and one to be proud of. It may well be worth the effort of doing a patent search (google patents and freepatentsonline.com help the individual inventor get a start) as well as a search of the web for similar designs. (Remember that what matters is that you were first to invent, not first to patent. Even if you were to get a patent, if someone were to demonstrate that the device had been invented 50 years ago they could have your patent overturned... regardless of whether the original inventor had filed for a patent or not. There is a whole section of patent law on the issue of "first to file" vs. "first to invent", but your main concern here is to look for "prior art"... ie. has anyone done this before?) It may also be worth going through the exercise of setting up a small-scale production run, developing a brand name for your product, and marketing your product just as an educational exercise. If it turns a profit... great! Jason P.S. Also remember that a patent doesn't prevent someone from using your idea... it merely gives you the right to sue them for damages if they do... and a US patent only protects ideas in the USA. If a US patent is expensive, then protecting your idea world-wide is phenomonally expensive (any idea what it costs to get a patent translated in to Japanese?) That doesn't mean don't "go for it" if you want the experience... in many ways the educational value of developing your design is likely to be far, far greater than the commercial value... just as the educational value of building a FIRST robot is far, far greater than any commercial applications the robots might have. P.P.S. Should you decide to patent in Canada, I can introduce you to some excellent Canadian patent agents who know a thing or two about FIRST. Last edited by dtengineering : 18-08-2008 at 13:40. |
From a patenting point of view it is also extremely helpful to know exactly what the "prior art" is so that you can describe precisely how a design differs from the prior art and what benefits your design offers. Perhaps this design is simpler to produce, is more reliable, uses less expensive materials, or is easier to adjust. If you don't know about prior art, and sufficiently differentiate your product from what has come before, you may spent a whole lot of time and money getting a patent only to discover that you can't enforce it due to the prior art... so knowing that there are similar designs out there in the public domain is useful for the inventor. It is extremely difficult to come up with a revolutionary mechanical design. After centuries of designing developments tend to be evolutionary rather than completely new. Often those incremental improvements are quite profitable and quite worth patenting, even though they may only improve performance in some small way. I can see how this design offers some incremental improvements over what I've seen before... and the suggestion to use a hose clamp is possibly another incremental improvement. Given that the discussion of patents, in the absence of a business plan, is purely academic, knowing that there have been similar desgins in no way marginalizes the "great idea" factor for the designer. So rather than viewing your comments as a downer, I'd view them as evidence that this design is on the right track! Jason |
I know you're in discussions, so I won't comment specifically on that. One option is to simply give them the idea for free (or some minor consideration, like a 20% discount on your next order). But, that depends on whether they 'want' something like that, or think it will sell. They have some small risk in the cost of manufacturing and inventory, but the risk is small only because the cost is low. Another alternative is to ask AndyMark to market the product, and you simply supply it. They have little upfront expenses, aside from a web page on their site. You have a small expense, making several samples and a small stock for them to hold on to for orders. And you can make a few dollars for the team, or for yourself. Just beware that if a LOT of teams want these, you may need to buy materials and make hundreds or even thousands* of them in just a few days - during build season. Getting a whole team to help - who gets the money? - might ease this worry. I'm not meaning to suggest that AndyMark will do this, I'm just using their name as an example. *We can only hope! Don |
Oh, heck... here's someone who's written it up better and more authoritatively than I http://www.lawmart.com/searches/difference.htm That is the value of a patent... it truly protects the idea of the design, which is the fundamental part of the invention rather than just an expression of the idea. Jason P.S. Good luck with manufacturing and marketing your design. It looks like a design that is extremely well-suited to mass production and once you get your jigs worked out you should be able to churn them out by the hundreds fairly quickly. Last edited by dtengineering : 18-08-2008 at 22:23. |
Think about how many of these you need to make, how quickly each one needs to be made, and how much you need to sell them for to break even. Then think about how many you think you can possibly sell. If you do the math, I don't think it's a viable investment to try to mass produce these, or even make them on a fairly large scale. To actually make money you need to be injection molding, not milling these. Injection molding is orders of magnitude more expensive than even the most generous estimate of demand for these. Given demand, and cost of contracting these out to a machine shop, or time involved in making them yourself, I don't think you can come out on top. Especially given that anyone with a manual mill or even drill press with x+y table can make one of these in about 15 minutes. Keep in mind that if you choose to make them or have someone else machine them, you have to be able to meet the criteria of a vendor, as well as be capable to potentially ship one to every team in FIRST, if they ordered one, within x time period (I think 5-7 days? can't recall). |
But I strongly disagree with the need to have them injection molded in order to turn a profit. The elegance of this particular design is that, as I have mentioned, it can be mass produced in a woodwork shop. The table saw is great for cutting long straight lines and long deep grooves. If you look at the jigs used for creating finger joints that might give you an idea how to make repeated, evenly spaced cuts. Do the cuts on one side of a sheet of HDPE, flip it over, turn it 90 degrees and do the cuts in the opposite direction, then slice it and cut to length to turn out the final product. This will require a bit of R&D... talking to someone with some fine woodworking experience would be a big help. I would also suggest prototyping the production process using a less expensive material, such as MDF, until the jigs are worked out and acceptable tolerances are achieved. For an investment of probably less than $200, plus hours and hours of work, it is quite possible to have hundreds of these produced and ready to go very quickly. I don't think anyone is going to become a millionaire off of this, but the beauty of it is that done properly any financial losses... even if sales are terrible... will be offset by the educational value of going through the entrepreneurial process. Go for it! Jason |
#10
Umm, so let me get this straight if you used this as a chain tension device than how long would it last due to the chain grinding against it. Also chain has that special pattern to it with that wouldn't it get locked up on the edges of this device? might want some sort of bearingS to prevent friction but that is just me.
#11
I would have to see some test data before i make any real judgment on things since the world is full surprises.
#13
Go to mcmaster.com and type in 5973K1. My idea is based off of this but has a different way of tightening it and is superior in price and quality. Here is my final design of it:
We have been using Mcmaster Carr tensioners and chain does not get locked into the tensioner. UHMW is a very good plastic for this application and the side walls are usually never hit due to the smaller side walls. It is fit for both #25 and #35 chain. Last edited by R.C. : 21-08-2008 at 23:47. |
#14
).Delrin (and UHMW) are both engineering plastics that have very low friction, and both work great for chain tensioners of various kinds. I prefer Delrin where possible since it machines very nicely (you can mill it really fast too), but it does cost quite a bit. But if you want proof of plastic chain tensioners, here's a photo from Team 228's 2007 robot. ![]() The white plastic circles are either Delrin (back one) or UHMW (front one). You can also see a third Delrin one on the drivetrain through one of the chassis rail lightening holes in the back. These are really simple ones: plastic rod with an off-center hole. As you rotate it around, it varies the radius; and by cranking down the bolt, it will hold its position. The Delrin ones held up the entire year (about five competitions and a lot of other random driving) with barely any noticeable surface scratches. The UHMW ones had small (about 1/16") grooves in them from the chain. (There was no particular reason why certain ones were Delrin and others UHMW; they just happened to be whichever our machinist mentor grabbed from the stockpile when making them.) |
#15
Greg & Jason,
Thank you for setting me straight on the copyright issue, and for your thorough discussions. I've mentioned this discussion to "those I mentioned in my post" who use this practice, but they swear it would hold up in court...oh well... |
| Flexible Floating Idler Tensioner | AndyB | Technical Discussion | 23 | 22-07-2008 11:05 |
| pic: Kitbot Chain Tensioner 2 | Donut | Extra Discussion | 13 | 10-12-2007 15:57 |
| pic: Kitbot Chain Tensioner 1 | Donut | Extra Discussion | 6 | 21-12-2006 00:43 |
| Chain tensioner usage | Rhs953 | Kit & Additional Hardware | 3 | 10-02-2004 17:04 |
| Chain Tensioner? | Gabriel | Technical Discussion | 14 | 29-01-2004 09:16 |
