Go to Post Invest our time in enhancing the process of conceiving, designing, testing and deploying the game - billylo [more]
Unread 19-08-2008, 00:19
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: Floating Zip Tie Chain Tensioner
Originally Posted by dtengineering View Post
P.S. Good luck with manufacturing and marketing your design. It looks like a design that is extremely well-suited to mass production and once you get your jigs worked out you should be able to churn them out by the hundreds fairly quickly.
I think it'd be best for him to step back and view this from an economical perspective.
Think about how many of these you need to make, how quickly each one needs to be made, and how much you need to sell them for to break even.
Then think about how many you think you can possibly sell.
If you do the math, I don't think it's a viable investment to try to mass produce these, or even make them on a fairly large scale.
To actually make money you need to be injection molding, not milling these. Injection molding is orders of magnitude more expensive than even the most generous estimate of demand for these.
Given demand, and cost of contracting these out to a machine shop, or time involved in making them yourself, I don't think you can come out on top. Especially given that anyone with a manual mill or even drill press with x+y table can make one of these in about 15 minutes.
Keep in mind that if you choose to make them or have someone else machine them, you have to be able to meet the criteria of a vendor, as well as be capable to potentially ship one to every team in FIRST, if they ordered one, within x time period (I think 5-7 days? can't recall).
2001-2004: Team 100
2006-Present: Team 254
Unread 19-08-2008, 00:26
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
That is why I am talking to Andy Mark, but Cory. Do you think these will sell if they are priced just right???
R.C.
MadTown Robotics Team 1323
Unread 19-08-2008, 14:43
dtengineering's Avatar
AKA: Jason Brett
I'll agree with the importance of researching the market as part of a business plan. I would have a hard time seeing how someone could get rich manufacturing these tensioners, however I have no problem believing that they could be manufacutured profitably. Potentially the greatest profit to be had from marketing and manufacturing them is the experience of developing a business plan, refining the production techniques, setting up a business and running it. Even if the business runs at a small loss having that on a resume and that exeperience as part of a professional tool set will be worth thousands of dollars....
But I strongly disagree with the need to have them injection molded in order to turn a profit. The elegance of this particular design is that, as I have mentioned, it can be mass produced in a woodwork shop. The table saw is great for cutting long straight lines and long deep grooves. If you look at the jigs used for creating finger joints that might give you an idea how to make repeated, evenly spaced cuts. Do the cuts on one side of a sheet of HDPE, flip it over, turn it 90 degrees and do the cuts in the opposite direction, then slice it and cut to length to turn out the final product.
This will require a bit of R&D... talking to someone with some fine woodworking experience would be a big help. I would also suggest prototyping the production process using a less expensive material, such as MDF, until the jigs are worked out and acceptable tolerances are achieved.
For an investment of probably less than $200, plus hours and hours of work, it is quite possible to have hundreds of these produced and ready to go very quickly.
I don't think anyone is going to become a millionaire off of this, but the beauty of it is that done properly any financial losses... even if sales are terrible... will be offset by the educational value of going through the entrepreneurial process.
Go for it!
Jason
Unread 21-08-2008, 21:40
UndergroundVoid's Avatar
UndergroundVoid UndergroundVoid is offline
System Ready...
AKA: Lynx
UndergroundVoid is a jewel in the roughUndergroundVoid is a jewel in the roughUndergroundVoid is a jewel in the roughUndergroundVoid is a jewel in the rough
Send a message via AIM to UndergroundVoid
Umm, so let me get this straight if you used this as a chain tension device than how long would it last due to the chain grinding against it. Also chain has that special pattern to it with that wouldn't it get locked up on the edges of this device? might want some sort of bearingS to prevent friction but that is just me.
I refuse to go silently into the night by taking the easy way out.
The manual doesn't have all the answers since nobody can plan for everything.
Things can be more simple than you think.
Unread 21-08-2008, 21:45
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Its obviously not as efficient as something that rotates, but the plastic used is relatively low friction. I also imagine that the side walls do not hit the side of the chain unless the chain is moving side to side somewhat.
Unread 21-08-2008, 21:50
System Ready...
AKA: Lynx
I would have to see some test data before i make any real judgment on things since the world is full surprises.
Unread 21-08-2008, 23:39
R.C.'s Avatar
Go to mcmaster.com and type in 5973K1. My idea is based off of this but has a different way of tightening it and is superior in price and quality. Here is my final design of it:
We have been using Mcmaster Carr tensioners and chain does not get locked into the tensioner. UHMW is a very good plastic for this application and the side walls are usually never hit due to the smaller side walls. It is fit for both #25 and #35 chain.
R.C.
Unread 21-08-2008, 23:44
Joe G.'s Avatar
AKA: Josepher
what is the purpose of the holes on the front and back?
Unread 21-08-2008, 23:51
R.C.'s Avatar
Say that you want to tension the chain on an arm robot. The chain is going vertically, so you add springs to each side of holes and the tensioner now just hangs: suspended by springs and it still tensions the chain. Also you can attach zip ties or springs to limit how far it floats or if you just want it to stay stationary. Example shown below:
Look at the white tensioner on the lift mechanism, it is suspended by springs and zip ties. The sprockets lifting the arm were of different sizes (a 60 tooth and a 15 tooth), so the tensioner had a tendency of diving down to the smaller sprocket.
R.C.
Unread 29-08-2008, 01:15
AKA: Jason Brett
I can see why you would want two different sized grooves for the chain to accommodate both #25 and #35 chain, but do you need the different sized grooves for the zip ties, too?
I ask only because it would seem to save a few manufacturing steps to put only a single groove in for each zip tie.
In a similar vein, would it, perhaps, be easier to drill the holes ALL the way through the tensioner? That way you would only need to do two drilling operations rather than four.
You may have a different production path in mind than I envision (as I've mentioned, I see this being an ideal shape to cut on a table saw). For instance with a CNC router, putting in extra grooves would require little in the way of additional manufacturing time. But if you are going to be kicking these out by the hundred using some manual production method, you probably want to include optimizing the production path as part of your design process.
Just a few thoughts that occurred to me without having "seen inside your head" to know why you made these design choices... perhaps I have overlooked something perfectly obvious to you. If so, my apologies.
Jason
Unread 29-08-2008, 02:13
NickE's Avatar
NickE NickE is offline
_
I agree that the 2 grooves for zipties seems unneccesary, and that the holes could go all the way through.
Another thing to consider:
If you were to make 2 different models for two different sizes of chain, it would simplify your design immensely.
I doubt many teams will be switching their tensioners between different sizes of chain very often.
Just because there is demand for more than one chain size, doesn't mean you need to incorporate all sizes into one product
Honestly, I liked your original design better. I think the most recent one you posted looks too complicated and time-consuming to machine.
Unread 29-08-2008, 12:07
R.C.'s Avatar
Guys, the reason for one tensioner is that we used the #25 Tensioner for both 25 and 35 chain and it worked perfectly. There will be no machining, i am probably going to have a mold for this made. I will probably end up changing the final design after all the comments and after more test runs of this tensioner.
Thanks Cd
R.C.
Unread 29-08-2008, 17:46
AKA: Jason Brett
Thanks Cd
If you are molding it then I would suggest rounding the exterior edges and corners. You might also want to think about putting some draft in to your design, and possibly stamping a product name, website or trademark in to the side as part of the molding process.
I hope that the sales volume is sufficient to cover the up-front cost of the tooling.
Jason
Unread 29-08-2008, 18:10
Cory's Avatar
AKA: Cory McBride
Jason
Unless he's got someone to make him a mold for free, there's just no way he can make a profit off these. The cost of getting a mold made is going to be extremely extremely high if it's being paid for.
2001-2004: Team 100
Unread 29-08-2008, 19:47
R.C.'s Avatar
Talking Re: pic: Floating Zip Tie Chain Tensioner
I have a company in mind
R.C.
Flexible Floating Idler Tensioner AndyB Technical Discussion 23 22-07-2008 11:05
pic: Kitbot Chain Tensioner 2 Donut Extra Discussion 13 10-12-2007 15:57
pic: Kitbot Chain Tensioner 1 Donut Extra Discussion 6 21-12-2006 00:43
Chain tensioner usage Rhs953 Kit & Additional Hardware 3 10-02-2004 17:04
Chain Tensioner? Gabriel Technical Discussion 14 29-01-2004 09:16
