Go to Post Canadian teams would definitely be able to give some of the "big boys" a run for their money. Despite the fact that their money is worth more than ours... =) - Karthik [more]
Unread 19-08-2008, 09:47
JesseK JesseK is online now
Re: pic: Floating Zip Tie Chain Tensioner
Last night I took this into the preliminary CADs my team has for our '09 prototype bases, and we noticed an inherent flaw. Perhaps this is a flaw with all floating tensioners though.
If the two sprockets in the chain run are significantly different relative to their distance apart (e.g. 22-tooth to a 32-tooth, 6" apart) or their axes of rotation are not level with each other (e.g. transmission output shaft is higher than the wheel axle), this tensioner will have a tendendency to "drift" towards the smaller or lower sprocket and stay there without putting any tension on the chain. Is this correct or are we seeing something that isn't really true?
GitHub
Unread 19-08-2008, 09:58
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
That is true but with this design it is not a problem. On the tops there are spots where you can drill holes and put springs in them so they don't lean one way or the other too much. We had to do this with the original floating tensioners, but they didn't have any spots to drill holes into them (a super hassle and a waste of time).
R.C.
MadTown Robotics Team 1323
Unread 19-08-2008, 11:01
Zflash's Avatar
Zflash Zflash is offline
AKA: Erich Zende
FRC #1319 (Flash)
Zflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud of
Installation of a snap idle : Enough tension need only be applied to take out the slack of the chain. When the drive is in operation the SnapidleŽ will move back and forth on the chain periodically.
This is a qoute from the snap idle page I referenced earlier. While we did not have such a large difference between our sprockets in use your application may still work due to the snap idle's slight movement. It wouldn't hurt to give it a try. If you do let us know.
Flexible Floating Idler Tensioner AndyB Technical Discussion 23 22-07-2008 11:05
pic: Kitbot Chain Tensioner 2 Donut Extra Discussion 13 10-12-2007 15:57
pic: Kitbot Chain Tensioner 1 Donut Extra Discussion 6 21-12-2006 00:43
Chain tensioner usage Rhs953 Kit & Additional Hardware 3 10-02-2004 17:04
Chain Tensioner? Gabriel Technical Discussion 14 29-01-2004 09:16
