Go to Post Its always good to read the rules yourself rather than listen to "word of mouth" rules. - Killraine [more]
Unread 19-08-2008, 09:53
Re: pic: 6w/d Chain base
You could go with 3x1 tubing and angle aluminum for mounts to the transmissions. One angle aluminum piece on top of the 3x1 and one on the bottom, which should cover the 5" face of the transmission for mounting. The angle aluminum could be attached to the 3x1 via welding or via riveting.
Weight savings should be roughly 4.5 lbs assuming a 36"x27" base. Since that's 4.5 lbs of pure aluminum, it'd wind up being less expensive as well.
GitHub
pic: Base Idea kajeevan Extra Discussion 10 27-07-2008 16:56
Circle base vs. Rectangle base Pelicano234 Technical Discussion 13 15-01-2008 16:49
pic: "Driveable Base" Cody Carey Extra Discussion 6 27-01-2007 23:29
pic: 1024 Base Michael Long Robot Showcase 4 17-02-2006 08:53
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
