Go to Post “Chasing perfection is like trying to find a unicorn. If you go all around the world, you will not find a unicorn. However, you will find a whole freak load of stuff along the way.” - Karthik - Jacob Bendicksen [more]
Unread 19-08-2008, 22:54
M. Mellott's Avatar
CAD God
AKA: Mike Mellott
Re: pic: 6w/d Chain base
With your choice of using inner and outer frame rails to support your wheels, plus your use of standoffs (or what appear to be standoffs) between the frame members to protect the wheels in case of a side hit, you could use 4" x1" U-channel in place of the box tubing--that would save a lot of weight. Adding cross members (at least 1, probably 2), as suggested by RMS11, would be a good addition...and you could get away with using 1/16" wall on the cross members.
pic: Base Idea kajeevan Extra Discussion 10 27-07-2008 16:56
Circle base vs. Rectangle base Pelicano234 Technical Discussion 13 15-01-2008 16:49
pic: "Driveable Base" Cody Carey Extra Discussion 6 27-01-2007 23:29
pic: 1024 Base Michael Long Robot Showcase 4 17-02-2006 08:53
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
