Go to Post Technology is everywhere, yet the human factor is what makes an event special. - synth3tk [more]
Unread 21-08-2008, 10:37
Leav's Avatar
Leav Leav is online now
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Re: pic: Rookie Testing Platform
Originally Posted by Katie_UPS View Post
Careful though, we had trouble with 6" mecanum wheels.
could you elaborate, please?
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 21-08-2008, 13:58
commodoredl commodoredl is offline
AKA: Dan Lavoie
FRC #2877 (LigerBots)
commodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud of
http://www.chiefdelphi.com/forums/sh...ad.php?t=68572
It seemed that the problem was the durability of the wheels. Andy said that the future iteration of these wheels would have several upgrades (listed in the thread), so you might want to wait until they come out before purchasing the mecanums in that size.
Technical Mentor
Team 2877 - Ligerbots
2016-
Previously:
Team 578 - Red Raider Robotics
2007-2014
Unread 23-08-2008, 19:27
Rupnick's Avatar
Rupnick Rupnick is offline
FRC #1675 (UPS - Ultimate Protection Squad)
Rupnick is on a distinguished road
Send a message via AIM to Rupnick
The problems 1675 experienced with the 6 in wheels where that there was not enough distance between then roller edge and plate edge causing the plates to grab into the carpet making any turning or strafing impossible. That was mostly remedied by taking each wheel and grinding each and every edge down. I took Ryan and myself a total of 3 hours to grind the 4 wheels. that doesn't count removing the stripping the rollers, reattaching the rollers, and mounting the wheel at the following regional. Also we had problems with the plates them selfs concaving under the strain of strafing.
AndyMark is redesigning the wheels with the corners removed and thicker plates for the 2009 FRC season. Granted they will get a tad heavier but, they are so much smoother and smaller then the 8 in.
As for the X vs O thing.
Mecanum can be used in 2 different "orientations" we played with this for the 2007 season. X gives you more turning but less strafing, O gives you more strafing less turning, so thats how that works, your not "wrong" but you may not be using the orientation you need for the specific game.
Brown is the New Gold
Unread 26-08-2008, 15:55
ubermeister's Avatar
ubermeister ubermeister is offline
AKA: Eric VA
ubermeister is a jewel in the roughubermeister is a jewel in the roughubermeister is a jewel in the roughubermeister is a jewel in the rough
I'm pretty sure both orientations would give you the same quality strafing, but that you absolutely need an X on top.
The reason is that with O, your rollers on the bottom look like an X. Since the rollers roll perpendicular to their axle, X on the bottom allows the robot to spin around freely. This doesn't sound like much of a problem (until you're getting spun around on the field), except for this:
You can't turn under power with X on the bottom. All the force that would be turning the robot is redirected by the rollers into an X pattern rather than an O pattern. So the robot is really pushing inwards on itself when it tries to turn, rather than pushing itself around.
Sorry if that's confusing. The bottom line is that O on top doesn't allow turning at all, and rather causes the robot to skid and jump around. You need X on top if you want to turn.
Unread 26-08-2008, 16:23
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
If your mecanum wheels are placed in a rectangle rather than a perfect square, you actually can manage to turn if they're installed with the wrong orientation. The vectors won't all cancel completely unless all the roller axes intersect at a single point.
They still cancel to a large extent, and it still doesn't turn very well.
The proper configuration has the rollers angled so that each of the wheels could move freely in a direction toward or away from the center of the robot without the wheel itself turning.
Unread 26-08-2008, 20:16
Dowjonesbotics's Avatar
Dowjonesbotics Dowjonesbotics is offline
Leggooo
AKA: Jeremy Downes
FRC #1230 (Lehman Lionics)
Dowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the rough
I would use the smaller wheels if u decide to use mecanumatic wheels.
My account had been hacked and used by someone random for the past 2 years, my apologies for so many awful posts.
2011 New York City Regional Regional Finalist
2009 New York City Regional Team Spirit Award
2008 New York City Regional Team Spirit Award
2007 New York City Regional Team Spirit Award
2005 New York City Regional Champion
2003 New York City Regional Rookie All-Star
pic: Platform Pile Up Joe J. Regional Competitions 14 13-03-2006 11:47
pic: Alliance Platform Wetzel Extra Discussion 2 08-01-2006 22:56
pic: Testing Rob Robot Showcase 3 16-02-2005 19:24
pic: Time machine platform Koko Ed Extra Discussion 4 13-01-2005 23:18
pic: 6 and 12 inch platform rise CD47-Bot Extra Discussion 2 18-01-2004 09:15
