Go to Post This should go without saying, but for some reason it always needs saying. - GaryVoshol [more]
Unread 21-08-2008, 23:39
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: pic: Floating Zip Tie Chain Tensioner
Go to mcmaster.com and type in 5973K1. My idea is based off of this but has a different way of tightening it and is superior in price and quality. Here is my final design of it:
We have been using Mcmaster Carr tensioners and chain does not get locked into the tensioner. UHMW is a very good plastic for this application and the side walls are usually never hit due to the smaller side walls. It is fit for both #25 and #35 chain.
R.C.
MadTown Robotics Team 1323
Unread 21-08-2008, 23:44
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
what is the purpose of the holes on the front and back?
Unread 21-08-2008, 23:51
R.C.'s Avatar
Say that you want to tension the chain on an arm robot. The chain is going vertically, so you add springs to each side of holes and the tensioner now just hangs: suspended by springs and it still tensions the chain. Also you can attach zip ties or springs to limit how far it floats or if you just want it to stay stationary. Example shown below:
Look at the white tensioner on the lift mechanism, it is suspended by springs and zip ties. The sprockets lifting the arm were of different sizes (a 60 tooth and a 15 tooth), so the tensioner had a tendency of diving down to the smaller sprocket.
R.C.
Unread 29-08-2008, 01:15
dtengineering's Avatar
AKA: Jason Brett
I can see why you would want two different sized grooves for the chain to accommodate both #25 and #35 chain, but do you need the different sized grooves for the zip ties, too?
I ask only because it would seem to save a few manufacturing steps to put only a single groove in for each zip tie.
In a similar vein, would it, perhaps, be easier to drill the holes ALL the way through the tensioner? That way you would only need to do two drilling operations rather than four.
You may have a different production path in mind than I envision (as I've mentioned, I see this being an ideal shape to cut on a table saw). For instance with a CNC router, putting in extra grooves would require little in the way of additional manufacturing time. But if you are going to be kicking these out by the hundred using some manual production method, you probably want to include optimizing the production path as part of your design process.
Just a few thoughts that occurred to me without having "seen inside your head" to know why you made these design choices... perhaps I have overlooked something perfectly obvious to you. If so, my apologies.
Jason
Unread 29-08-2008, 02:13
NickE's Avatar
NickE NickE is offline
_
I agree that the 2 grooves for zipties seems unneccesary, and that the holes could go all the way through.
Another thing to consider:
If you were to make 2 different models for two different sizes of chain, it would simplify your design immensely.
I doubt many teams will be switching their tensioners between different sizes of chain very often.
Just because there is demand for more than one chain size, doesn't mean you need to incorporate all sizes into one product
Honestly, I liked your original design better. I think the most recent one you posted looks too complicated and time-consuming to machine.
Unread 29-08-2008, 12:07
R.C.'s Avatar
Guys, the reason for one tensioner is that we used the #25 Tensioner for both 25 and 35 chain and it worked perfectly. There will be no machining, i am probably going to have a mold for this made. I will probably end up changing the final design after all the comments and after more test runs of this tensioner.
Thanks Cd
R.C.
Unread 29-08-2008, 17:46
AKA: Jason Brett
Thanks Cd
If you are molding it then I would suggest rounding the exterior edges and corners. You might also want to think about putting some draft in to your design, and possibly stamping a product name, website or trademark in to the side as part of the molding process.
I hope that the sales volume is sufficient to cover the up-front cost of the tooling.
Jason
Unread 29-08-2008, 18:10
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Jason
Unless he's got someone to make him a mold for free, there's just no way he can make a profit off these. The cost of getting a mold made is going to be extremely extremely high if it's being paid for.
2001-2004: Team 100
2006-Present: Team 254
Unread 29-08-2008, 19:47
R.C.'s Avatar
Talking Re: pic: Floating Zip Tie Chain Tensioner
I have a company in mind
R.C.
Unread 30-08-2008, 18:42
Gary.C Gary.C is offline
OUTWORK US
Gary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond repute
Send a message via AIM to Gary.C
Really cool invention, so this year we can replace the mcmaster carr tensioners. Will buy
Unread 03-09-2008, 12:54
R.C.'s Avatar
This product is finally going to be released. Andymark is going to mold and sell this. So thank you everyone that replied and helped me. The final design is not shown.
Thanks CD
R.C.
Unread 15-01-2009, 15:28
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Looks like AndyMark is stocking these now!
http://andymark.biz/am-0286.html
Unread 15-01-2009, 15:34
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
1529 will be sporting these fancy accessories on our 2009 robot. They just came in today and they look awesome.
Hi!
Unread 15-01-2009, 15:53
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
I bought a pair for my control system practice bot. They come in a great package with 2 rubber bands and 3 zip ties.
The robot was originally built for a college capstone project. The bot worked great except the chains would fall off. I haven't had a chance to try the tensioners yet.
"FIRST is like bling bling for the brain." - Woodie Flowers
Flexible Floating Idler Tensioner AndyB Technical Discussion 23 22-07-2008 11:05
pic: Kitbot Chain Tensioner 2 Donut Extra Discussion 13 10-12-2007 15:57
pic: Kitbot Chain Tensioner 1 Donut Extra Discussion 6 21-12-2006 00:43
Chain tensioner usage Rhs953 Kit & Additional Hardware 3 10-02-2004 17:04
Chain Tensioner? Gabriel Technical Discussion 14 29-01-2004 09:16
