Go to Post Everyone needs to start working with what they are given, and start appreciating FIRST, not complaining about what they think FIRST is doing wrong. - Marygrace [more]
Unread 25-08-2008, 01:22
EricH EricH is offline
Re: pic: Omnibot
Originally Posted by Aren_Hill View Post
Im almost completely positive 67 in 2005 was a 3 wheel swerve with no omni's involved.
you can see the front two wheels here : http://www.chiefdelphi.com/media/photos/20772
I'm pretty sure it was a kiwi-type system, like below. I tried to search, but no luck yet.
Unread 25-08-2008, 01:27
Re: pic: Omnibot
Nope, sorry Eric, but 67 definitely had a 3 wheeled crab in 2005.
Unread 25-08-2008, 01:31
Re: pic: Omnibot
Actually, I found a picture... of 67 2005... in a match... on two wheels, showing the third. NOT a true swerve. Swerve, yes. Three wheeled robot, yes. But not a three-wheel swerve. One wheel steered, three drove. Zoom in on the picture. One wheel is turned; the others appear not to be able to.
Unread 25-08-2008, 01:39
Re: pic: Omnibot
Actually, I found a picture... of 67 in 2005...during build... on the ground, showing all three wheels. A true swerve, with all three wheels able to rotate.
No hard feelings eric
Unread 25-08-2008, 14:16
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Re: pic: Omnibot
If you move the wheels to opposite corners the math will work out exactly the same as it would for the configuration shown.
There are two advantages that a holonomic base built using this configuration has over a swerve drive:
1) The modules are lighter and less complex.
2) The robot can translate and rotate at the same time (I've seen this called "frisbee motion")
The programming is more complex, but there are plenty of examples available to get you started.
Unread 25-08-2008, 23:22
Re: pic: Omnibot
And rotate independently... No wonder the code took so much space in the controller.
Back on topic: If you're going to do 3WD, plan it out first. Carefully. As noted, only one robot (to our knowledge) has had a 3WD omni system; most of the other 3WDs were crab/swerve systems.
Unread 25-08-2008, 23:30
Data Nerd
FRC #0079
Re: pic: Omnibot
Also, the one robot that did a 3 wheeled omni (857) didn't use code to control their wheels, they used hardware (http://www.chiefdelphi.com/media/photos/16410) Dont forget that sometimes that solution works better than complex code. No reason to make the code more complex than it needs to be. Could it be done in code? Yes, is complex code always better? That is up to you.
Unread 26-08-2008, 20:15
Dowjonesbotics's Avatar
Dowjonesbotics Dowjonesbotics is offline
Leggooo
AKA: Jeremy Downes
FRC #1230 (Lehman Lionics)
Dowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the rough
Re: pic: Omnibot
Cooool, are those the robots that spin really really fast??
My account had been hacked and used by someone random for the past 2 years, my apologies for so many awful posts.
2011 New York City Regional Regional Finalist
2009 New York City Regional Team Spirit Award
2008 New York City Regional Team Spirit Award
2007 New York City Regional Team Spirit Award
2005 New York City Regional Champion
2003 New York City Regional Rookie All-Star
pic: Omnibot Ryan M. Extra Discussion 18 03-08-2005 08:19
