Thread Tools |
Rating:
Display Modes |
Re: pic: Omnibot
Nope, sorry Eric, but 67 definitely had a 3 wheeled crab in 2005.
Re: pic: Omnibot
Re: pic: Omnibot
Actually, I found a picture... of 67 in 2005...during build... on the ground, showing all three wheels. A true swerve, with all three wheels able to rotate.No hard feelings eric ![]() |
Re: pic: Omnibot
If you move the wheels to opposite corners the math will work out exactly the same as it would for the configuration shown.
There are two advantages that a holonomic base built using this configuration has over a swerve drive: 1) The modules are lighter and less complex. 2) The robot can translate and rotate at the same time (I've seen this called "frisbee motion") The programming is more complex, but there are plenty of examples available to get you started. |
Re: pic: Omnibot
Back on topic: If you're going to do 3WD, plan it out first. Carefully. As noted, only one robot (to our knowledge) has had a 3WD omni system; most of the other 3WDs were crab/swerve systems. |
Re: pic: Omnibot
Re: pic: Omnibot
Cooool, are those the robots that spin really really fast??
| pic: Omnibot | Ryan M. | Extra Discussion | 18 | 03-08-2005 08:19 |
