Go to Post You're here for them, not for you. - Chris is me [more]
Unread 01-09-2008, 22:58
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: pic: FRC 1771 Drivetrain
Thanks for the advice. This will be done on a CNC so lightening patterns may show up on this if we decide to do it. Although ~35lbs for a drivetrain may prove that reducing weight is unnecessary.
I will take into consideration the issue with bumpers flexing.
On a seperate note does anyone have any experience with UHMW wheels, specifically in a cantilevered scenario like this.
Mentor 2415
Unread 01-09-2008, 23:45
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
every ounce matters dude, ask us. we were 4 pounds underweight and we got to atlanta, over by .1 pounds. also what are the ratios for the gears you used to achieve your fps? stick with aluminum wheels or andy's new plaction wheels. if you have the time, do uhmw wheels for the pre season. one of our capitans made them when he went to college and said that they need tread on them and that they last for a long time. the wheels were used on a go-cart.
R.C.
MadTown Robotics Team 1323
Unread 01-09-2008, 23:56
AKA: Sean
Yeah I will look into cutting weight out of the frame. As for the wheels, I really want to go custom for a lot of reasons. Primarily we can get the exact size we want (5"), they are also keyed for hex shaft without a hub, and finally they are way cheaper as the material to make 12 wheels only costs ~$70. The wheels will of course be treaded with roughtop or wedgetop. I guess I am primarily asking for the durability of the actual uhmw portion of the wheel and if we go this route we will probably have a full set of spares with us at all times
Mentor 2415
Unread 02-09-2008, 01:21
run the trap!!!
Team Role: Human Player
I'm worried about hex-broaching plastic. Doesn't seem like a good idea to me. Might want to go with some of those Al AM hubs.... or wheels....
For the record you CAN buy 5" plastic wheels for less than $70.
-Philip J. Fry
Unread 02-09-2008, 01:35
R.C.'s Avatar
Yeah, I agree with Hachiban. Hexing UHMW is harsh, our capitan put ball bearings in them and it worked fine, but hexing is a different story. Where can you get 5 inch plastic wheels???
R.C.
Unread 02-09-2008, 16:43
s_forbes's Avatar
anonymous internet person
FRC #0842 (Falcon Robotics)
The frame looks great, nice and simple, and the bumper mounts are a very clever approach. I'd avoid cheese-holing it if I were you... It's already very light! Just put as much thought into your mechanisms as you did into this drivetrain and you won't have any weight problem at all.
And belts are awesome!
$6-7 a piece (about $15 each if you get them with aluminum hubs):
http://banebots.com/c/WHB-HS6-498
Unread 02-09-2008, 17:05
AKA: Sean
Those wheels are definitely worth a look however I am going for something with a bit more traction (roughtop). I am also debating doing a finesse version of this one using custom omni wheels in the corners and a center traction wheel plus single speed. I just finished my single speed and with it I have gotten this drivetrain under 30lbs (~29.5)
Mentor 2415
Unread 01-09-2008, 23:58
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
I would be concerned about losing the bumpers with you're bumper mounts. I looks like if you got into a good pushing battle that you're bumpers could end up coming off.
Also, one of the big benefits for the west coast drive is it's maintainability. When designing something always ask yourself what do I do if X breaks, how do I repair or replace X? What happens if you break a belt? Right now it looks like you'd have to remove and disassemble part of the transmission in order to do that. That's probably going to be a lengthy repair. I would recommend using 25 chain instead.
Even if the numbers are in your favor, it's best to have the ability to repair something rather than leave it to chance. You never know what could happen.
Team 1538 / The Holy Cows, 2005-2016
Unread 02-09-2008, 00:01
R.C.'s Avatar
Talking Re: pic: FRC 1771 Drivetrain
Anything that can go wrong, will go wrong and yeah: use #25 chain (weight saver).
R.C.
Unread 02-09-2008, 00:07
AKA: Sean
Yes in order to change a belt the transmission would have to be removed. I figure the entire operation would take slightly longer than putting on a chain however the weight savings for a belt versus even #25 chain is pretty significant. This would be something that we would really have to weigh the tradeoffs on before deciding. Plus the belts really have a cool factor and Ive been wanting to try them for a while.
Mentor 2415
Unread 02-09-2008, 00:10
Jon Jack's Avatar
VEX Robotics
no team (No Team)
I don't think 25 chain is lighter than belts, I would just use 25 chain to make the drivetrain easier to maintain. Another thing to consider too is that belts will stretch more than chain. This means that the slots that the front/read bearing houses sit it will have to be longer to pick up any slack created from the stretching.
Unread 02-09-2008, 00:19
R.C.'s Avatar
Belts will break, a team posted that and it happened at the San Diego Regional. Chain is the way to go unless you have an expert helping you. Also, belts need to be tensioned before and after each match, this may become bothersome after a few matches. FIRST gets interesting and people tend to forget minor things, I know my team did. Ahh the good times.
R.C.
Unread 02-09-2008, 00:26
AKA: Sean
Actually belts stretch much less than chain. In multiple posts by team 125 they talk about there belts not stretching at all after initially tensioning them. they rely on kevlar belt which is very strong stuff. The only positive I see to the chain is that it is easier to change if it breaks. In all other aspects, belt is the superior solution.
Mentor 2415
Unread 02-09-2008, 00:29
AKA: Sean
I forgot to post the gear ratios so here goes. The first stage is 12 to 48 reduction, and then the second stage is either a 15 to 60 or 30 to 45 reduction.
Mentor 2415
Unread 02-09-2008, 00:32
Dancin103 Dancin103 is offline
The Crazy Blonde
AKA: Cassie
FRC #0103 (Cybersonics)
Rookie Year: 1997
Dancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond repute
Send a message via AIM to Dancin103
Other than needing to loose a few pounds, i would say it looks good. Keep up the good work.
Cybersonics Technology Team 103
2003 Championship Chairman's Award Winners
NEED CHAIRMAN'S HELP?? Subscribe to our YouTube Channel, we answer your questions daily!
pic: FRC 1771 Swerve Module sdcantrell56 Extra Discussion 17 13-04-2008 00:36
pic: FRC 1771 Swerve sdcantrell56 Extra Discussion 5 10-04-2008 16:17
pic: 1771 drivetrain machining sdcantrell56 Extra Discussion 3 15-02-2008 17:26
pic: 1771 drivetrain complete 2 sdcantrell56 Extra Discussion 4 12-01-2008 00:57
pic: 2008 drivetrain 1771 sdcantrell56 Extra Discussion 9 10-01-2008 11:55
