Go to Post Our robot will use sensors to collect information about its environment, then discard that information and drive into a wall. - Jared Russell [more]
Unread 01-09-2008, 23:56
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: pic: FRC 1771 Drivetrain
Yeah I will look into cutting weight out of the frame. As for the wheels, I really want to go custom for a lot of reasons. Primarily we can get the exact size we want (5"), they are also keyed for hex shaft without a hub, and finally they are way cheaper as the material to make 12 wheels only costs ~$70. The wheels will of course be treaded with roughtop or wedgetop. I guess I am primarily asking for the durability of the actual uhmw portion of the wheel and if we go this route we will probably have a full set of spares with us at all times
Mentor 2415
Unread 02-09-2008, 01:21
run the trap!!!
Team Role: Human Player
I'm worried about hex-broaching plastic. Doesn't seem like a good idea to me. Might want to go with some of those Al AM hubs.... or wheels....
For the record you CAN buy 5" plastic wheels for less than $70.
-Philip J. Fry
Unread 02-09-2008, 01:35
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Yeah, I agree with Hachiban. Hexing UHMW is harsh, our capitan put ball bearings in them and it worked fine, but hexing is a different story. Where can you get 5 inch plastic wheels???
R.C.
MadTown Robotics Team 1323
Unread 02-09-2008, 16:43
s_forbes's Avatar
anonymous internet person
FRC #0842 (Falcon Robotics)
The frame looks great, nice and simple, and the bumper mounts are a very clever approach. I'd avoid cheese-holing it if I were you... It's already very light! Just put as much thought into your mechanisms as you did into this drivetrain and you won't have any weight problem at all.
And belts are awesome!
$6-7 a piece (about $15 each if you get them with aluminum hubs):
http://banebots.com/c/WHB-HS6-498
Unread 02-09-2008, 17:05
AKA: Sean
Those wheels are definitely worth a look however I am going for something with a bit more traction (roughtop). I am also debating doing a finesse version of this one using custom omni wheels in the corners and a center traction wheel plus single speed. I just finished my single speed and with it I have gotten this drivetrain under 30lbs (~29.5)
Mentor 2415
pic: FRC 1771 Swerve Module sdcantrell56 Extra Discussion 17 13-04-2008 00:36
pic: FRC 1771 Swerve sdcantrell56 Extra Discussion 5 10-04-2008 16:17
pic: 1771 drivetrain machining sdcantrell56 Extra Discussion 3 15-02-2008 17:26
pic: 1771 drivetrain complete 2 sdcantrell56 Extra Discussion 4 12-01-2008 00:57
pic: 2008 drivetrain 1771 sdcantrell56 Extra Discussion 9 10-01-2008 11:55
