Re: pic: FRC 1771 Drivetrain
I would be concerned about losing the bumpers with you're bumper mounts. I looks like if you got into a good pushing battle that you're bumpers could end up coming off.
Also, one of the big benefits for the west coast drive is it's maintainability. When designing something always ask yourself what do I do if X breaks, how do I repair or replace X? What happens if you break a belt? Right now it looks like you'd have to remove and disassemble part of the transmission in order to do that. That's probably going to be a lengthy repair. I would recommend using 25 chain instead. Even if the numbers are in your favor, it's best to have the ability to repair something rather than leave it to chance. You never know what could happen. |
Yes in order to change a belt the transmission would have to be removed. I figure the entire operation would take slightly longer than putting on a chain however the weight savings for a belt versus even #25 chain is pretty significant. This would be something that we would really have to weigh the tradeoffs on before deciding. Plus the belts really have a cool factor and Ive been wanting to try them for a while.
I don't think 25 chain is lighter than belts, I would just use 25 chain to make the drivetrain easier to maintain. Another thing to consider too is that belts will stretch more than chain. This means that the slots that the front/read bearing houses sit it will have to be longer to pick up any slack created from the stretching.
Belts will break, a team posted that and it happened at the San Diego Regional. Chain is the way to go unless you have an expert helping you. Also, belts need to be tensioned before and after each match, this may become bothersome after a few matches. FIRST gets interesting and people tend to forget minor things, I know my team did. Ahh the good times.
Actually belts stretch much less than chain. In multiple posts by team 125 they talk about there belts not stretching at all after initially tensioning them. they rely on kevlar belt which is very strong stuff. The only positive I see to the chain is that it is easier to change if it breaks. In all other aspects, belt is the superior solution.
I forgot to post the gear ratios so here goes. The first stage is 12 to 48 reduction, and then the second stage is either a 15 to 60 or 30 to 45 reduction.
Other than needing to loose a few pounds, i would say it looks good. Keep up the good work.
My bad, i was talking about fatigue of the belt. They are just plastic, belts are great if you can use them and chain is just a tad bit easier to maintain and good luck with whatever you go with. BTW, nice cad job. |
#10
Im hoping I can get this drivetrain under 30 lbs. I havent made one yet that could actually function that was that light. Im working on a single speed version in case there is no need for a shifter like this past year.
#11
35 pounds is a very admirable weight for a rolling drivebase. Very few teams have made theirs lighter.
#12
I don't know of any place to purchase 5" plastic wheels from other than colson wheels which are not hey keyed and which do not allow for tread attachment. Also the price of $70 is not per wheel that was the approximate price that itwould cost us to make 12 wheels, enough for 2 robots.
Has anyone actually tried broaching UHMW or any plastic for that matter? I would think it wouldn't be a problem but if that is not the case then I have to change my plan. I agree and was under the assumption that anything under 35lbs or even 40lbs is a light drivetrain. I now have 2 drivetrains designed under 35lbs, one cantilevered and the other using plates and standoffs. |
#13
![]() Of course, it's quite a bit easier to hit these low weights when you drop a CIM motor or two. ![]() |
#14
Exactly. If we dropped a cim per transmission this would automatically be 5.5lbs less. Also the spur gear style transmission is heavier than a dewalt. Additionally this frame has more metal than yours. It is true we could possibly shave ~1-2lbs out of the frame, but the amount of machining might not be worth it if we know well ahead of time that we will make weight. A ~30lb drivetrain is imo very light particularly with a 2 speed transmission and 2 cims.
I am working on an updated version that uses custom hubs in the wheels and that has some more details added and Ill work on getting it up soon. |
| pic: FRC 1771 Swerve Module | sdcantrell56 | Extra Discussion | 17 | 13-04-2008 00:36 |
| pic: FRC 1771 Swerve | sdcantrell56 | Extra Discussion | 5 | 10-04-2008 16:17 |
| pic: 1771 drivetrain machining | sdcantrell56 | Extra Discussion | 3 | 15-02-2008 17:26 |
| pic: 1771 drivetrain complete 2 | sdcantrell56 | Extra Discussion | 4 | 12-01-2008 00:57 |
| pic: 2008 drivetrain 1771 | sdcantrell56 | Extra Discussion | 9 | 10-01-2008 11:55 |
