Go to Post The robot is never 'done' there is always something that can be done to improve it. - Jonathan Norris [more]
Unread 15-09-2008, 12:03
Woodie Flowers Award
Ken Patton Ken Patton is offline
purple
FRC #0051 (Wings of Fire)
Rookie Year: 1997
Ken Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond repute
Re: pic: Mammoth GearBox1
Theres some good advice on this thread, hope you are seriously considering what they said, rc_cola.
One item not yet covered - if you are going to use a sprocket on the output shaft to drive a chain drive, you should think about the shaft loads that will result from the chain when the motors are at full load and the wheels are stalled. The chain load can be pretty high for a drive with this output torque.
One other thing you might consider - the standoffs that you are using there look pretty skinny. Along with making sure you have adequate strength of the sideplates (as Greg already said), I would make sure you have enough contact area between the standoffs and the side plates.
Ken
Unread 15-09-2008, 12:31
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Thanks for all the suggestions:
-Pocketing the gearboxes was because we wanted to try out the CNC and with Cosmos it tells us that the plates are plenty strong enough. They are 7068 plates at 1/4 inch. So the plates are just for fun.
-The mentors were going over the specs and said that the 3 inch cims would be better for a 2 stage reduction.
Thanks everyone.
R.C.
MadTown Robotics Team 1323
Unread 15-09-2008, 15:06
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Thanks everyone.
7068? You're just playing with fun materials, rather than trying to economize, right?
And as for the big CIMs, all things being equal, it's probably sensible to get rid of those somehow.
Unread 15-09-2008, 17:42
run the trap!!!
Team Role: Human Player
I suppose you really want to make a gearbox... because a tough box with spacers weighs only 1.77 lbs...
How big is the mammoth? Will you be mechanizing the head? If you do, post some pics, since that sounds really cool!
-Philip J. Fry
Unread 15-09-2008, 17:56
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
... and if you swap out the steel 50 tooth cluster gear for the aluminum 50 tooth cluster gear, you can save another 0.31 lbs.
Andy B.
Unread 15-09-2008, 18:06
Engineering Mentor
FRC #0254
Andy B.
What a sneaky guy we have here...
Edit: Looks promising. How's the 6061 holding up?
-Travis Covington
Unread 15-09-2008, 18:20
R.C.'s Avatar
The 7068 is coming as a donation from one of our near by metalshops and i'll try to get rid of the big cims.
Yeah, we kinda wanna CNC some stuff and i'll put pics up tomorrow. The mammoth is huge and the head will be moving.
Andy B.
Thanks Andy, Make sure to do that.
R.C.
Unread 15-09-2008, 18:49
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
Andy B.
Well it's about time AM offered Aluminum gears! Can't wait to see how these perform.
thanks, Vivek
Unread 21-09-2008, 00:04
R.C.'s Avatar
Man time does fly, I'll put up some pics of the actual mammoth on tuesday or monday depending on when i can get them.
Here's some the prototyped plates in plastic and prototyped wheel for next year and for the mammoth.
R.C.
pic: team 1305 - The Mammoth Ayu Robot Showcase 2 04-03-2004 23:33
