Go to Post Woah, boulders fired. - FrisbeeFunTime [more]
Unread 29-09-2008, 18:26
DonRotolo's Avatar
Back to humble
FRC #0832
Re: pic: drivetrain idea (comments please)
#25 chain is more sensitive to proper tensioning. #35 allows teams to be really sloppy and still quite effective.
As to the original question: I like the idea, very similar to our 2007 robot. We used a kitbot frame with a second level of frame at the height of the top of the wheels, primarily to get a flat platform.
Your implementation seems somewhat heavier than necessary. The inner rail doesn't add much strength, it can be 1/16" wall, while the outer rail will take a beating, count on bumpers to stiffen it and lend impact resistance.
You also need to consider cross-rails from outer to inner rail, and again from one inner rail to the other - that way, an impact's force is transmitted to all four elements, not just the one impacted.
If you can mount the gearboxes lower - gotta think about the sprocket wrap - you can end up with a flat (or nearly so) platform over which your manipulator can be built.
Don
pic: A drivetrain prototype idea GMAdan Extra Discussion 16 24-04-2007 16:14
A new drivetrain Idea? Cody Carey General Forum 55 20-08-2006 12:48
Crazy drivetrain idea lukevanoort Technical Discussion 7 26-10-2005 21:19
Crazy Idea, looking for comments archiver 1999 74 23-06-2002 22:56
Another idea looking for comments archiver 1999 16 23-06-2002 22:01
