Go to Post I see all these people complaining about the FIRST game having perverse penalties for playing defense...then we play without defense, and still people complain. - MrForbes [more]
Unread 30-09-2008, 19:15
Re: pic: drivetrain idea (comments please)
You'll really want to attach the frame members at more than just the ends. I would attach the two outer rails to each other between each wheel at a minimum, and since you're welding, it'll be real simple to do.
Originally Posted by JOhnch181 View Post
for cross bracing are team used a heet of 1/2" plywood to create reidgity from side to side. It has the second benefit of giving you a flat surface.
You can use just about any material, but if fastened in enough places, it creates a sheer-web that greatly increases the rigidity of the frame. Depending on the material, you may also need a centered crossbrace to keep it from sagging.
Originally Posted by M. Mellott View Post
I would add a cross-brace (1x1 square tubing, 1/16" wall) to keep the frame strong and square...maybe two. They would also serve as additional mounting points for electronic boards and other devices.
As already suggested, using 1/16" wall tubing for the inner frame members is a good idea, but it may not be readily available in the 1x2 size you've chosen (not saying that it's not out there). In the case where you cannot find the 1/16" wall stuff, 1/8" wall U-channel would be a good option to save weight.
I have found 1/16" wall 2x1 to be very available.
pic: A drivetrain prototype idea GMAdan Extra Discussion 16 24-04-2007 16:14
A new drivetrain Idea? Cody Carey General Forum 55 20-08-2006 12:48
Crazy drivetrain idea lukevanoort Technical Discussion 7 26-10-2005 21:19
Crazy Idea, looking for comments archiver 1999 74 23-06-2002 22:56
Another idea looking for comments archiver 1999 16 23-06-2002 22:01
