Go to Post this is robotics--everything is going to go wrong at some point, it's how we deal with it that counts - abigailthefox [more]
Unread 08-10-2008, 20:44
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: pic: Andymark's New Product
Originally Posted by MikeDubreuil View Post
I'd like to make a suggestion for this thread and the AndyMark website...
I have been following the development of this product since the first CAD drawings were posted on CD. Now, I think I'm a fairly smart guy... college educated and a pretty good software engineer.... it took me a very long time to realize these would be used as a pair and tie wrapped together. Now I realize why everyone thought the idea was so beautiful in its simplicity.
Now for the suggestion... could you show a picture of it used on a robot? I think that would help people (maybe I'm the only one) understand how to use it and why it's so effective.
As for the picture of this thing in action, I will take one tomorrow and upload it and why it is so effective:
-Lightweight
-Cheap
-No maintenance
-Easy Removal (We wasted so much time taking the snap ones on and off).
-Can be left floating or can be made stationary
-No lubrication
Originally Posted by Elgin Clock View Post
Ok. I can safely comment about those curved features now.
In our typical chassis designs, we run our chain in a very tight area between 2 metal plates. I'm concerned in our design (and in similar one's I've seen) that those tabs are sticking out way too much to be effective & not get snagged on those plates, or anything mounted inside those plates. (Bronze bushings, spacers, screw heads, etc...)
We had our frame spaced so tightly one year in terms of area between plates, that a rushed replacement socket head cap screw (rather than the original flat head screw) actually popped the chain right at the link in the finals match of a competition.
I love this design, but I'm just saying that if we were to use these, we would more than likely just use zip-ties, not use the rubber bands or o-rings (which I think will wear out even more quickly over a competition anyways and require more maintenence - even more so than the blocks themselves with the concerns Greg N. posted) & we would probably cut or shave those curved tabs right off.
Just a thought from someone with bad experience with a hardware vs chain matchup in a real world design application.
Of course, your results may vary.
The zipties don't wear really, you could ideally go 7-8 matches without even worrying about the zip ties. As long as you cut the ends of the zip ties off. If the frame is really too tight. We used only one of the blocks then. We mounted it in between and made it stationary. If you upload a pic of your frame. I could give you solution. We had this problem when we were using the mcmaster carr ones 3 years ago.
R.C.
MadTown Robotics Team 1323
Unread 08-10-2008, 20:55
Zflash's Avatar
Zflash Zflash is offline
AKA: Erich Zende
FRC #1319 (Flash)
Zflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud of
Having used the snap idle version I know how those are pulled together in order to keep the chain properly tensioned. With this you either use ty wraps or o-rings. My question is how easy is it to get enough tension on the ty-wrap without having to use a ty-wrap gun since most chassis do not have the room for it.
Unread 08-10-2008, 20:59
Aren_Hill's Avatar
Build Nifty Things
I like the simplicity, but it puts too many things out of control for me, such as the slack between the two sides when the sprockets change directions would be undesireable in my opinion. Our method was swiped from 118 with nice tensioners that just involve tweaking a screw a little tighter. And the chain loops were stable and not whipping around all over the place.
the main reason they wouldn't work to well in our situation is the proximity to victors... so no whippage room was available, kinda cause the swerve drive. We may use them elsewhere though it looks like a solid product, congrats
efficiency wise ball bearing idler sprockets and pulling the drive/driven sprockets to adjust the chain wins vs sliding on plastic
A guy who likes robots.
Unread 08-10-2008, 23:13
R.C.'s Avatar
You could always tension these with a hose clamp if you wanted to.
R.C.
pic: 397 Final product HUNT397 Robot Showcase 0 24-02-2006 18:57
pic: Team 358 - The Final Product DarkJedi613 Robot Showcase 11 01-03-2005 08:19
pic: Team 1110 Final Product (sort of) RudimentaryPeni Extra Discussion 0 01-03-2005 01:11
pic: 820's finished product JKnox Robot Showcase 17 24-02-2005 19:22
