#31
Re: pic: Concept 8wd Drivetrain
The 2008 1680 design was 8 wheel drive with a 4 in line (no drop) profile. Each side comprised 2 separate modules of: 1 - 2.5inch cim motors with a 3.57 reduction (14:50 gearing) 1 - 6inch "First Wheel" direct driven in the middle front or rear position and 1 - 6inch AM Omni Wheel at the outside corners driven by 25 chain from the directly connected center wheels. This gave us.
And new to this disscussion ... Fault Tolerance. Each side could maintain some motive force with the following failures
Granted Multi speed transmissions may have some mechanical advantage here. But there's no reason you couldn't have different mechanical ratio's and electronically gear the drive pairs. Imagine... the rear module geared down for pushing, the front module geared for speed, under load (pushing/acceleration)the rear pair could receive max current and the front would operate at a reduced level... until the rear has reached its "slip" limit... the current drive would then be redirected to the front (still at a loaded condition)... this would pull the now unloaded rears to an rpm above that which they have torque at. Presto.. two separate velocity profiles, no gear changes. Something to consider. PS 3.57:1 as a final drive ratio was a little fast last year (34ft/sec) |
| pic: Concept Mecanum Drivetrain | sdcantrell56 | Extra Discussion | 10 | 07-02-2008 11:56 |
| 8WD drivetrain? | David Sherman | Technical Discussion | 16 | 09-04-2006 17:32 |
| pic: Concept Gearbox | Bill_Hancoc | Extra Discussion | 12 | 17-11-2005 20:54 |
| pic: Claw^2 Concept | CD47-Bot | Extra Discussion | 8 | 06-02-2004 14:08 |
| pic: Crab Concept 6 | CD47-Bot | Extra Discussion | 13 | 14-11-2003 22:03 |
