Go to Post Ineveitably what we do just might end up in the hands of millions of people. - JoeXIII'007 [more]
Unread 29-10-2008, 02:09
Re: pic: FRC1293 Prototype 6wd Chassis
If you guys have the tools to do it, I would recommend that you fold the top of the side plate over to make it a lot stiffer and stronger.
We made a drive train last year that was 2 plates of 1/8" aluminum side plates on either side of our wheels with spacers to hold the plates together. We folded the top and bottom of each plate over to make a 1/2 inch or so tab. It held up very well.
Unread 29-10-2008, 10:34
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
First off, I'd like to say this looks like a great design, very weight friendly.
1902 has done it two different ways the last two years. In 07 it was flat 1/8" plate with a ton of rivets and spacers.
http://www.chiefdelphi.com/media/photos/26796
Last year it was lots of rivets, spacers, and we flanged the top and bottom of the plates. We did this because in 07 the frame seemed to warp a bit with impacts and what not. It never was a problem because the bumpers are strong enough to support quite an impact, so the bumpers ended up keeping the drive plates relatively sturdy.
http://picasaweb.google.com/DanRRich...00838081699890
However bending the plates, when femed showed an individual panel was much stronger. ( If I remember correctly it was "14x" stronger but the flat plate failed under the loading so take that for what you will. ) For 1902 the verdict was, 1/8" is ok.., but 1/8" with 2 .5" bends are SOO much better. Its not too hard to find a sheet metal break, or a metal fab shop to do this for you, for free, or really cheap. I suggest if your going with 1/8", trying to throw some bends on that bot.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 29-10-2008, 12:31
Zflash's Avatar
Zflash Zflash is offline
AKA: Erich Zende
FRC #1319 (Flash)
Zflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud of
All parts of a ROBOT between 0 and i belive it was 8.5 inches from the
ground that are used to push against or interact with an
opposing ROBOT must be within 10 degrees of vertical.
This was the rule in previous years it may change. This is just a friendly warning so that you do not have to change anything at an event. The design looks clean and open for easy access to the various systems. Do you have any wieght values yet?
Unread 29-10-2008, 13:21
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I don't think those chamfered parts would ever interact with another robot, and by my entirely unofficial interpretation of a previous year's rule, would be ok.
2001-2004: Team 100
2006-Present: Team 254
Unread 29-10-2008, 13:30
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Don't forget a way to attach bumpers (assuming they'll be mandatory in '09)
Hi!
Unread 29-10-2008, 13:31
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
However, all of the angled bits hanging down past the bottom flat part are unnecessary material. It is not gaining the design any strength and the extra weight could be avoided by eliminating it all together. Possibly make the entire bottom of the frame flat with a 1/2" flange for extra strength.
Mentor 2415
Unread 29-10-2008, 13:32
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
It could, but probably only the top. I was planning on creating a small 5" bumper plate that covers the front of the sideplates. It would attach using the same holes as the spacers.
It would have the added benefit of making us legal, AND keeping stuff out of the wheels ;-). the bot shouldn't weigh more than 50 or so pounds with the electronics (not including battery), but i'll work in inventor for a bit and come up with an accurate calculation of its total weight sooner or later.
Also i'll look into a shop that can do some flanges for us so I don't have to use any UHMW to back and reinforce the aluminum. Thanks for the tips so far.
:edit: The extra bit around the wheels are mostly a safety precaution to just keep stuff from jabbing into the KOP wheels, they arn't the sturdiest wheels around.
Unread 29-10-2008, 13:46
AKA: Sean
Thats true but imo the added weight is not worth the small small chance that something gets in the spokes and kills the wheel. If something were to happen, it would be a quick swap anyways.
Mentor 2415
Unread 30-10-2008, 01:01
Thermal's Avatar
Drive Team Coach
AKA: Ryan Brown
with the way the toughboxes are mounted, I cannot make the center part of the chassis smaller than 5" tall, so I'm going to keep the inside chamfers.
However I'll think about flattening the front and rear and cutting some material off.
Thanks again for the tips.
Unread 30-10-2008, 01:25
It doesn't have to be that tall on both sides though.
Unread 29-10-2008, 13:45
Zflash's Avatar
AKA: Erich Zende
FRC #1319 (Flash)
The bottom chamfer is fine (Team 1319 has done that in the past) however the top chamfer does create a wedge like surface (which is why we haven't). While I totally agree with you that the top chamfer would not ever come in contact with other robots I was just pointing out what I have seen teams have to fix at a regional in the past. I suppose they would have much rather have had you as an inspector.
6WD Chassis Stiffness vs. Maneuverability IKE Technical Discussion 35 07-12-2008 16:04
pic: 6WD Design Iteration Madison Extra Discussion 7 01-01-2008 14:00
Need pictures of chassis for 6WD team2061 CAD 6 24-12-2007 14:51
pic: 226 Off-Season Prototype Chassis Matt Reiland Robot Showcase 2 01-02-2005 19:33
