Go to Post Cheaters never win, winners never cheat. :) - Amanda Morrison [more]
Unread 31-10-2008, 16:41
M. Mellott's Avatar
CAD God
AKA: Mike Mellott
Re: pic: FRC1293 Prototype 6wd Chassis
Originally Posted by Thermal View Post
Real sideplates will probably be 1/8" 6061 alu backed with 3/8" UHMW, the prototype will just be 1/2" plywood.
Nice design--looks like it can be assembled very quickly.
Why did you choose to use 1/2"-thick sideplates? Have you used this in the past and found that you need to go that thick? With the use of the spacers along with the heavy-duty 80/20 cross-beams, it seems like you could make them much thinner, especially if they're being protected by bumpers.
Also, are the wheel modules/side plates made to be universal, meaning that you could use the same pieces on either the left or right sides?
Unread 06-01-2009, 23:12
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
Yes, the sideplates are universal, the assemblies are just mirrored from each other.
As an update we changed the look but it is still the same basic design. We are now using 1/8" thick 6061 alu sheet with flanges on the top and bottom of the sideplate to prevent warping. 4" long, 5/8" diameter UHMW dowels for the spacers with 4 1/2" long 1/4"-20 bolts to go through the dowels and hold the sideplates together. We made some changes to the 8020 and repositioned them pretty drastically for more room for the manipulator, and we have also changed our wheel locations slightly to allow easier turning for this year.
6WD Chassis Stiffness vs. Maneuverability IKE Technical Discussion 35 07-12-2008 16:04
pic: 6WD Design Iteration Madison Extra Discussion 7 01-01-2008 14:00
Need pictures of chassis for 6WD team2061 CAD 6 24-12-2007 14:51
pic: 226 Off-Season Prototype Chassis Matt Reiland Robot Showcase 2 01-02-2005 19:33
