Go to Post You do use CAD to prototype, Cardboard Aided Design. - Peter Matteson [more]
Unread 07-11-2008, 09:37
spc295 spc295 is offline
FRC #0295 (Renevatio)
spc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to behold
pic: milled chassis
Unread 07-11-2008, 09:39
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: pic: milled chassis
It looks good overall. A couple improvements that could be made: You should add some support higher up on the frame to keep the side pieces from wanting to bend in or out. Also, the angle on the front and back is not going to last long and it will be very flexible. I would personally use more tube, either 1" square or 2"x1". Also, possibly put an angle on the front and back of the side plates to increase your approach and departure angles for ramp climbing.
Overall though it looks very nice. Good job
Mentor 2415
Unread 07-11-2008, 14:02
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
This design would benefit greatly by having some sort of plate bolted to the bottom of the chassis to stiffen everything up.
2001-2004: Team 100
2006-Present: Team 254
Unread 07-11-2008, 15:22
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
belly pan baby
mike d
See Ya
How much does it weigh?
Unread 07-11-2008, 18:28
8.2 lbs. with the screws and weld and standoffs.
295 Team Captain
pic: 2430 Chassis Boydean Extra Discussion 2 09-02-2008 12:10
pic: Top Chassis Rick TYler Robot Showcase 1 04-02-2006 19:13
pic: 195 Chassis Tom Bottiglieri Robot Showcase 14 09-02-2005 11:16
pic: Seven Chassis-es! CD47-Bot Robot Showcase 2 01-02-2004 15:03
Image Discuss: Our Newly Milled "WING" CD47-Bot Extra Discussion 10 15-02-2003 20:07
