Go to Post Come on guys, its not like it's rocket surgery or anything. - hallk [more]
Unread 09-11-2008, 13:25
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
Re: pic: 6 wheel suspension
Drawings are at http://www.team1322.org/ideas.htm under "six wheel omni".
It is semi independent suspension on all wheels but the right is separate from the left. Because the frame attaches at the two point’s center of each drive half (between the omni and mecanum) the frame lifts about half of the front wheel rise. No springs are required, the weight of the robot should keep it all down. We may add springs later if needed. We are thinking that we could add pneumatic control to help with it, also use it to lift the front wheels to get up onto a step. The weight is approximately 25 lbs for each drive assembly.
pic: 6 wheel omni directional with a suspension joeweber Extra Discussion 18 08-08-2008 19:31
pic: 6 wheel drive with a suspension joeweber Extra Discussion 18 07-08-2008 00:49
pic: 6 wheel drive with a suspension joeweber Extra Discussion 16 05-08-2008 00:32
pic: FRC 1726 suspension MrForbes Extra Discussion 4 22-12-2006 15:57
pic: vex suspension psyco_klown Extra Discussion 9 14-11-2006 22:18
