pic: 6wd chassis
Re: pic: 6wd chassis
This is an excellent job of listening to advice and incorporating the changes to make a superior product. Overall I think this is a great design so far. How thick are the plates? It looks like 1/8".
why thank you, but i still need to make a change i realized that by moving a standoff in order to cut the corners of the chassis it will now get in the way of the wheels
(edit) i looked at the other picture, answered my question
Last edited by gorrilla : 09-11-2008 at 17:44. Reason: question already answered |
to keep it safe and save money try to use 1/4" plate. looks great
How would 1/4" plate save money over 1/8" plate?
also it is steel or aluminum?
Aluminum if it is a 1/4" inch or 1/8" plates. No STEEL unless it is that really awesome thin-wall stuff.
It wouldn't.
#10
Well, it would if you kept breaking it and having to replace it. Obviously you need to make sure that 1/8 is strong enough to do what you want. You do NOT want to be burning money having to replace parts because they werent designed properly.
#11
1/4" thick is always more expensive because it is more material. In the age of bumpers, a properly supported 1/8" plate will more than stand up to the abuses of FIRST. If you want to increase the strength substantially without increasing weight by too much you could bend the plates on the top and bottom to create a flange. This will increase the stiffness of the plate dramatically.
#12
To paraphrase Ferris Bueller: "They are SO choice. If you have the means, I highly recommend adding a few." |
#13
If you have the patience to dig through it, there are a number of examples on how the location of material affects the strength and stiffness of a beam in this thread. http://www.chiefdelphi.com/forums/sh...ad.php?t=67605
#14
it is 1/8" alluminum 5052 alloy, so it is harder and stronger then other alloys.
#15
Why not use 2024 or 7075 if your not welding anything to those pieces. 7075 sheets have a brinell of 150 and a yield of 65 ksi.
| pic: FRC1293 Prototype 6wd Chassis | Thermal | Extra Discussion | 16 | 06-01-2009 23:12 |
| 6WD Chassis Stiffness vs. Maneuverability | IKE | Technical Discussion | 35 | 07-12-2008 16:04 |
| pic: 6WD Design Iteration | Madison | Extra Discussion | 7 | 01-01-2008 14:00 |
| Need pictures of chassis for 6WD | team2061 | CAD | 6 | 24-12-2007 14:51 |
| pic: 6WD Module | Madison | Technical Discussion | 20 | 12-01-2007 10:09 |
