Go to Post I will be here until the end of time working my butt off to inspire and enable the ever changing group of students that pass through our doors. - RoboChair [more]
Unread 18-11-2008, 03:23
spc295 spc295 is offline
FRC #0295 (Renevatio)
spc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to beholdspc295 is a splendid one to behold
pic: re-modified 6wd
Unread 18-11-2008, 03:26
Re: pic: re-modified 6wd
I don't recall the specific reasons people told you to add a bottom pan, but I assume it was mainly to make the frame more rigid, and to provide a structure to mount electronics to.
I think if you added a larger piece on the bottom, and made the gusseting thinner, you would like the results. You increase the rigidity of the frame substantially, and would get a light piece to mount components to.
Unread 18-11-2008, 09:38
we have always advoided mounting electronics to the chassis we always mount to lexan and then mount the lexan to the frame. we could not make the plate go any farther back because of the shifters, and i wanted to keep the plate centered
295 Team Captain
Unread 18-11-2008, 11:44
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
If the plate in the middle is the most you can do then it probably is not worth it to make it a plate. Instead just go back to a 2x1 tube. I think the best thing for this frame would be adding flanges on the side plates which would increase the stiffness dramatically. Overall though it is very nice.
I would caution you to carefully examine the upcoming game and to make your decision to use this chassis based on the way you want to play the game. Don't lock yourself into this design just because you have prototyped it.
Mentor 2415
Unread 18-11-2008, 14:21
Andy Baker Andy Baker is online now
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Neat design
Since we are discussing the bottom plate and electronics mount... why not combine the two? You could make your plate bigger, and get rid of the polycarbonate sheet at the same time. If you make that bottom plate out of 3/32 - 1/8" thick perforated aluminum, then you have a rigid bottom plate that doubles as an electronics mount panel.
Andy
Unread 18-11-2008, 15:44
Originally Posted by Andy Baker View Post
Neat design
Andy
what do you mean by perforated aluminum.
295 Team Captain
Unread 18-11-2008, 16:20
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
http://www.mechanicalmetals.com/perforatedmetals.html
2001-2004: Team 100
2006-Present: Team 254
Unread 18-11-2008, 16:21
Perforated Aluminum is a sheet of aluminum with a standard pattern of holes, hexagons, squares, etc. already cut into it. Search "Perforated Aluminum" on Mcmaster; however, I would advise against buying from them as I can only see very expensive sheets available.
Another option, since it appears you have your own waterjet/sponsor with one, is to cut your own bedpan similar to how 233 does it.
Unread 18-11-2008, 21:19
since we cant start cutting until kickoff I will arange the electronics on 3/32 aluminum plate then mark what we can waterjet out, and then draw the plans for the bellypan.
295 Team Captain
Unread 18-11-2008, 22:35
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
I would make the bottom plate out of 1/4"hardwood plywood. It's not only lightweight but also strong. Mounting electronics to it is a breeze too. Once you paint it, nobody can tell the difference,
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 19-11-2008, 10:25
yes but how would you mount it.
295 Team Captain
Unread 19-11-2008, 10:40
EricH EricH is offline
Flange the lower side of the inner plate, or weld on a small plate that you can put a bolt through.
Plywood is pretty strong, and the thicker versions have a lot of weight loss potential. In 2007, 330 had a very interesting pattern on the underside of its 1/2" plywood base. One of the mentors took a router to the bottom of the robot. He left a support structure for screws and bolts and took the rest down to half thickness or thinner. We had no problems that year with the base.
Unread 19-11-2008, 10:53
AKA: Sean
You could also do the mentioned 1/4" thick plywood or even go down to 1/8" thick and then laminate it with some fiberglass cloth and epoxy, which would make a very strong, stiff, and light board plus it would be very cheap and give you the opportunity to work with composites. Be sure to use a good plywood though like baltic birch or even better, 1088 meranti or okoume plywood.
Mentor 2415
Unread 19-11-2008, 13:18
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Laminating 1/8 won't increase the stiffness that much.
You want the skins on a lamination as far apart as possible to increase rigidity. If you're going to laminate, better to buy the 1 inch thick insulation styrofoam (blue or pink). Cut out (cheese hole) the styrofoam.
Lay your glass on an old doorwall window (get it for free off craigslist or the garbage) in whatever size you need, then use epoxy to glue it to the top and bottom of your lightened styrofoam.
You'll get essentially a honeycombed panel for far less cost.
Unread 19-11-2008, 15:04
you guys keep mentioning flanging as a way to mount things, I dont think we have a tool available to us that would do that, (i dont think we have ever done that) what would that tool be called?
295 Team Captain
pic: Modified Andy Mark 2 speed gearbox sam shawe Extra Discussion 3 29-04-2011 00:22
pic: Team 587 2008 modified joystick lukevanoort Control System 9 03-02-2008 22:04
pic: A nikko RC car, modified Andy A. Extra Discussion 11 20-03-2005 11:59
