Go to Post All robots can be defeated with strategy. - Alexander McGee [more]
Unread 19-11-2008, 17:38
Nate Smith Nate Smith is offline
FRC Key Volunteer Trainer
AKA: CrazyNate
Nate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to behold
Send a message via AIM to Nate Smith Send a message via Yahoo to Nate Smith
Re: pic: Night & Day
I wonder if the Jaguar has to be calibrated like the victor. First thing we should test is if the 'neutral' of the Jaguar is truly 127. There's a 'calibrating a victor' thread around here somewhere and I won't have a chance to even ask our team to do it until Tuesday.
According to Luminary Micro's getting started doc for the Jaguars, the answer is no...
Originally Posted by Jaguar Getting Started
Q Do I need to calibrate my Jaguar (MDL-BDC)?
A Depends, but probably not. The Jaguar (MDL-BDC) module does have a calibration mode; however, the need to use
the calibration mode is unnecessary if you are using a cRIO system and a new Jaguar (MDL-BDC)—because the
default parameters of the Jaguar (MDL-BDC) are tuned for use with a cRIO. The calibration mode is provided if you
want to use a Jaguar (MDL-BDC) with another source of Servo (PWM) signal that does not have the same range of
pulse widths (for example, an older robot controller). If you have calibrated your Jaguar (MDL-BDC) from a different
source and move it back to a cRIO system, you will need to recalibrate.
Nate Smith
nsmith@smythsoft.com
12 seasons, 4 teams, and more time logged behind the scorekeeper's table than I care to remember...
returning for 2011? only time will tell...
pic: CRT T-SHIRT Shooter At Night Kyle A Extra Discussion 7 21-09-2006 13:04
pic: Atlanta at Night (cloudy) Joe J. Extra Discussion 7 01-05-2006 21:24
pic: Mayhem Night Crew Tytus Gerrish Extra Discussion 7 11-07-2005 00:55
pic: David Kelly's long night D.J. Fluck Extra Discussion 3 20-03-2005 23:23
pic: 696 - The 1st late night CD47-Bot Extra Discussion 22 17-02-2004 06:45
