Go to Post Calculate everything. You won't need to make speed holes if you figure it all out beforehand and get it taken care of. - Otaku [more]
Unread 19-11-2008, 21:32
roboticWanderor's Avatar
Spark The Ancient
FRC #0418 (Purple Haze)
Re: pic: six wheel drive articulated stair climber
Story time!
This robot was built along side the foam shooter robot, as and off season project. the chassis was actually a left over prototype from the stair climbing / bar hanging year (idk date) our team members decided to put it to good use. if you look close, you can see the helix wear pattern in the closest front wheel from the master link!
also proof of yet another wooden chassis! this thing can stand as much punishment as any of our other robots! and I'm pretty sure it's pine, although you might want to ask bertman about that.
Best Form Of Six Wheel Drive? thefro526 Technical Discussion 54 28-03-2007 01:18
pic: FRC488 - Six Wheel Drive Chassis Madison Technical Discussion 38 23-01-2007 10:58
Tank Tread Stair Climber 114gopher Technical Discussion 9 12-12-2005 21:41
