Go to Post A Strong FRC Team Should... have a clear vision and an understanding of how to achieve it within their means. - jwfoss [more]
Unread 19-11-2008, 22:17
excel2474's Avatar
excel2474 excel2474 is offline
AKA: Aaron Stewart
FRC #2474 (Excel)
excel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the rough
Re: pic: Latest on wood-coast chassis
Originally Posted by roboticWanderor View Post
Story time!
assigned to create a demo robot by our coach, we decided to make an awesome pool noodle shooter. Due to grade deadlines, we had to abandon certain features such as an auto feeding magazine that could store more pool noodles, a tilt, and full 360 degree rotation capabilities. these may be added on by later classes of LASA Robotics seniors, and Twiggy, and its fantastic weapon (project racecar), will continue to evolve into a fantastic demo robot!
However, that dosen't make it the most awesome thing ever!!! the gravity fed hopper, pnumatic firing pin, and flywheels make for an impressive rapid fire.This thing makes a tremendous noise when spinning, and loves to shred pool noddles who don't behave!
The flywheels are actually zip tied to the aluminum Andy mark hubs, which in turn are JB welded to the output pinions of the bosh drill motors. true story.
As for the chassis and drive train, dewalt drills (including their original motors) power each side. This thing is pretty hefty, able to power it's way over dirt humps, up handicap ramps, through stacks of plastic crates, and can certainly try to bash its way though walls unharmed. I even managed to hop a curb with it.
hope yall enjoyed our project! we are really proud of it!
You should be proud of this one. This is a really cool idea for a demo robot. I was just trying to think of a good demo robot for out team to work on and this looks like a great idea. What size tube do you use for your barrel? And what type of material is it made of. I also love the turret, but i'm not exactly sure how it works. Do you have better pictures of the turret or a drawing? Congratulation on the awesome robot and good luck this year.
Aaron
"Find some thing you like to do and EXCEL at it with dilligence."
University of Notre Dame- Mechanical Engineering.
Unread 20-11-2008, 00:59
CraigHickman
Very nice! Did you have any bad experiences cutting the Red Oak? Also, what type of wood glue did you use? I know in the longboarding world, we love Titebond 3, but who knows what you folks used. That's really cool to see teams going for alternate frame materials... Bet you could swing some kind of award for that (A more "green" drivetrain)!
Unread 20-11-2008, 12:43
Bertman's Avatar
Bertman Bertman is offline
FRC #0418 (Purple Haze)
Bertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond repute
Thanks,
Cutting the red oak is simple. Just a sharp carbide tipped blade and a table sawand a sharp chissel. The joints are mortise & tennon with some assembly techniques used in boat building. For glue I used gorilla glue because I wanted to see how it held up (pretty good so far), though plain carpenters glue in a good joint would be more than sufficient.
Unread 20-11-2008, 12:47
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
So based off of this chassis, if you decided you wanted to use a west-coast style drivetrain would you make it out of wood or would you stick with aluminum? Have you thought about laying one layer of fiberglass on it as well?
Mentor 2415
Unread 20-11-2008, 21:15
Bertman's Avatar
That will be a team decision.
Unread 20-11-2008, 22:16
AKA: Sean
what is the general consensus right now. I guess my main question is given the choice of a west coast style drivetrain, is there any advantage in your mind that would sway your team from using a wood frame?
Mentor 2415
Unread 21-11-2008, 10:09
Bertman's Avatar
Not in my mind, The first five years we competed in FIRST we had a wooden chassis with zero failures. But wood is not the only alternative we are looking at so our decision process is not yet complete, and I am not the whole team. I do believe that with a good design and good manufacturing techniques wood is an excellent choice for a chassis. Just my $.02.
Unread 21-11-2008, 11:34
AKA: Sean
Thank you bertman. Thats the answer I was looking for. Basically a summary of the performance in relation to a similarly designed metal chassis. I have a question about construction. With the resources we have it would be easier to use plywood such as a quality okoume board since we could laser cut it. Do you think layering 2 pieces of 1/2" thickness together to get a thick enough piece for a bearing would be strong enough and would the thing as a whole be strong enough. It would all be epoxied together with some screws, and possibly wrapped in fiberglass. I too am very interested in alternative materials. I might end up building a chassis to try in the coming weeks.
Mentor 2415
Unread 21-01-2009, 11:48
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
is that the Keyang motor or the Nippon-Denso that runs on the flywheel gear
it look like a Keyang to me but poeple have been calling it the window motor and to me that means Nippon-Denso
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 21-01-2009, 12:26
CraigHickman
Looks like a Keyang, which would actually run the powered seats....
pic: Wood as an David Brinza Extra Discussion 4 08-04-2006 19:29
pic: 1346 - Wood is Good dtengineering Robot Showcase 21 14-02-2006 02:15
Input On Steel chassis w/wood inset Henry_Mareck Technical Discussion 36 20-12-2005 14:52
Space Ghost Coast to Coast to DVD Nov 18th!! D.J. Fluck Chit-Chat 7 07-11-2003 18:57
East Coast, West Coast, and Midwest FIRST Aaron Lussier General Forum 52 04-08-2003 01:52
