Go to Post theres nothing more macho than something made entirely out of diamond plate. - Dan9874123 [more]
Thread Tools Rating: Thread Rating: 3 votes, 4.67 average. Display Modes
Unread 11-21-2008, 08:09 AM
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
FRC #0829 (Digital Goats)
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
pic: Early Christmas!
Unread 11-21-2008, 08:10 AM
yodameister yodameister is offline
The Mad Chemist
FRC #2791
yodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant futureyodameister has a brilliant future
Re: pic: Early Christmas!
sorry, wrong thread.
Unread 11-21-2008, 08:35 AM
EricVanWyk EricVanWyk is offline
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Any comments on how the setup went?
Unread 11-21-2008, 08:36 AM
Data Nerd
FRC #0079
Very cool, how do the Jags work? Must be pretty simple to set up based on how quick this is up. Do all the connectors feel nice and secure?
Also I hate to criticize, really, but how do you debug electrical problems? Seems a little messy.
Unread 11-21-2008, 08:58 AM
Zflash's Avatar
Zflash Zflash is offline
AKA: Erich Zende
FRC #1319 (Flash)
Zflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud ofZflash has much to be proud of
Originally Posted by Richard McClellan
According to the Getting Started guide, it is recommended to have 1/2" of empty space on the left and right side of each Jaguar speed controller. If you were to mount two Jaguars with their sides adjacent to each other, can this 1/2" space overlap, or would you need a total of 1" of space in between the two?
Yes, the 1/2" space can overlap.
-This is a post from another thread I thought you might want to consider this. Congrats on being ahead of the curve.
Peachtree '08 Champion Thanks 343 & 547
Galileo '07 Champion Thanks 173 & 1902
Palmetto '07 Champion Thanks 832 & 342
Boilermaker '06 Champion Thanks 1272 & 85
Unread 11-21-2008, 09:03 AM
lenny8's Avatar
lenny8 lenny8 is offline
Aww Yea
AKA: L-Deezy
FRC #1018 (Robodevils)
lenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to behold
aww im so jealuoso, we havent gotten our system yet.
good job goats but, clean it up.
Learn something, Know Something, Do something
Unread 11-21-2008, 09:14 AM
IndySam's Avatar
IndySam IndySam is offline
Very quick and easy. Big thanks goes to More Robotics team 1714 for their advice on how to follow the manuals. It was a big help.
Bench testing took about an 2.5 hours and we did this setup in about an hour. Jags seam sweet on the bench. We didn't run it on carpet yet. That will be Saturday.
All the connectors worked fine. Wagos are easy to use.
No problem about the criticism This was quick and dirty just to see how it functioned. When we decide what operations to put on the robot for testing we will do a real installation.
Unread 11-21-2008, 09:40 AM
Please do share their advice!
Unread 11-21-2008, 09:50 AM
IndySam's Avatar
If they said it once they said it a thousand times....
The manuals do not flow in a linear pattern. You must be very careful how you follow them or you will be chasing your tail.
Chapter one will point you to a specific section in chapter 5 and only that section. Then that section may point you somewhere else. You have to be real careful to go where you are pointed and then back.
I would suggest that before you receive your control system that you download the manual and read if very carefully and familiarize yourself with it. It will make the whole process easier.
Unread 11-21-2008, 10:55 AM
Does anyone have advice on how we should label the wires? Is there a caveat that makes it necessary to do more than, say, "SC1-P13" (sidecar 1, port 13)? I haven't investigated the Labview code yet, so I don't know what the port nomeclature looks like in the code.
GitHub
Unread 11-21-2008, 11:05 AM
Data Nerd
FRC #0079
Personally, I would do two labels, "sc1-13" and what it corresponds to. This year our wires were labeled "pwm01" and "Left Drive" so we knew where to put it and what it was. Saved having to look it up.
Unread 11-21-2008, 11:07 AM
Stu Bloom's Avatar
FRC #1018 (RoboDevils)
Very quick and easy. Big thanks goes to More Robotics team 1714 for their advice on how to follow the manuals. It was a big help...
I agree that the 1714 presentation was EXCELLENT! It was very similar to their "webcast" which is archived here. In fact the NEOFRA site is a very good compilation of resources for the 2009 Control System.
I believe the webcast archive also has a link in the FIRST Beta Test forums.
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
My activity for 2012:
  • Midwest Head Ref - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 11-21-2008, 12:39 PM
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Stu,
Having seen the presentation, I also think it was excellent....do they have the PPP posted yet?
See you in Tel Aviv!
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 11-21-2008, 02:17 PM
CraigHickman
I have to say, not thrilled about the amount of size that these new electronics take up...
But hey, you take what you get, eh?
Unread 11-22-2008, 01:48 AM
O-H
FRC #0048 (Delphi E.L.I.T.E.)
OK....I'll bite. WHY do the manuals flow in this manner? Is it not possible to make them more "linear" for the betterment of all? If the info is complete but jumbled, can this not be corrected fairly easily?
pic: 987's Early Christmas present 1 KF987 Extra Discussion 13 01-08-2008 11:17 PM
pic: 987's Early Christmas present 2 KF987 Extra Discussion 9 12-10-2007 01:36 AM
pic: Merry Christmas AdamHeard Chit-Chat 6 01-18-2007 01:17 PM
pic: Early Drivetrain Gabriel Mendez Robot Showcase 10 01-28-2006 12:50 AM
pic: 1559 Drivetrain--early bradleym1559 Robot Showcase 2 03-07-2005 07:30 PM
