Go to Post Yeah After we decided not to do autonomous, the robot took matters into it's own hand. i'd bet it would get it's self DQ'd... or an award. - GMKlenklen [more]
Thread Tools Rating: Thread Rating: 3 votes, 4.67 average. Display Modes
Unread 11-22-2008, 02:21 PM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: pic: Early Christmas!
Originally Posted by Travis Hoffman View Post
OK....I'll bite. WHY do the manuals flow in this manner? Is it not possible to make them more "linear" for the betterment of all? If the info is complete but jumbled, can this not be corrected fairly easily?
There are two uses of the manual, one is to get people up as quickly as possible, the other is to provide the information in a logical manner for reference. Since teams will only get up and running once, but may need to use it for reference many times, Sections 2-5 of the manual were optimized for the latter use case. Section 1 provides the pointers to the needed parts in sections 2-5, in order for everyone to get up and running.
Unread 11-25-2008, 07:18 PM
darkember darkember is offline
AKA: Billy
FRC #0375 (Robotic Plague)
darkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of light
How do you get power to the router? When i looked at the istructions, it showed that it has to get connected to the power distribution board and the cRio. The only problem is that there is only one ethernet cable that came with the router and a power supply that has no use on a robot.
P.S. It would be nice for a picture of it.
Unread 11-25-2008, 07:35 PM
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
You need to make the power cable for it. Cut off the transformer part of the cable that comes with it and put a wago connector on it. Pay attention to polarity. If I remember correctly, the wire with the stripe is positive.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 11-25-2008, 08:23 PM
AKA: Billy
Thanks, that was one of the last things i have left to do on the controls to make it functional.
Unread 11-25-2008, 09:47 PM
Nosh's Avatar
Nosh Nosh is offline
Dead Head
AKA: Noah
FRC #0571 (Paragon)
Nosh is an unknown quantity at this point
"Holy S**t it's Christmas" was my reaction when we got the new electronics too, we got it running on a working bot ASAP... it was beautiful.
Unread 11-26-2008, 06:37 PM
AKA: Billy
I found something wierd. When the pneumatic bumper was plugged into the power distribution board and there wasn't any breaker, we were reading between 2-3 volts. When the breacker was plugged in we were reading the intended 12v. What i dont get is how we still got voltage without a breaker. Any Ideas?
Unread 11-26-2008, 09:07 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
There's obviously some leakage through the pneumatic breakout from the 9472 Digital Sourcing Module when the 12 volt power isn't connected. I don't have a copy of the breakout schematics handy, so I can't explain the current paths in detail.
Unread 11-26-2008, 10:46 PM
Applepwns's Avatar
Applepwns Applepwns is offline
Likes Waffles
AKA: Justin Murphy
FRC #0201 (FEDS)
Team Role: Marketing
Applepwns is an unknown quantity at this point
Im not really liking how much space all that is taking up..
Congrats on the working robot though!
Unread 11-27-2008, 12:44 AM
artdutra04's Avatar
VEX Robotics Engineer
Originally Posted by IndySam View Post
If they said it once they said it a thousand times....
The manuals do not flow in a linear pattern. You must be very careful how you follow them or you will be chasing your tail.
Chapter one will point you to a specific section in chapter 5 and only that section. Then that section may point you somewhere else. You have to be real careful to go where you are pointed and then back.
I would suggest that before you receive your control system that you download the manual and read if very carefully and familiarize yourself with it. It will make the whole process easier.
There's only one reason why the manuals could have possibly been written this way:
Assembly programmers.
Used to JMP'ing around all day, CMP'ing and MOV'ing data while dancing the PUSH and POP shuffle, they managed to write the manual to the new control system. Unfortunately for those not accustomed to the ways of lean and mean coding, reading the manual is like being stuck in the limbo of oh_no JMP oh_no.
Art Dutra IV
世上无难事,只怕有心人.
Unread 11-27-2008, 09:13 AM
Mark McLeod's Avatar
Mark McLeod Mark McLeod is offline
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Mark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond repute
Originally Posted by artdutra04 View Post
There's only one reason why the manuals could have possibly been written this way...
It's those hyperlink happy wiki editors!
The document would make better sense if it were able to hyperlink just to the isolated pertinent sections rather than cross-referring the reader into the middle of an entire chapter.
"Rationality is our distinguishing characteristic - it's what sets us apart from the beasts." - Aristotle
Unread 11-27-2008, 02:42 PM
EricVanWyk EricVanWyk is offline
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
There is ~100kOhms of leakage around the breaker on the PD. Your 2-3V isn't real, it will disappear as soon as any sort of load is applied.
Unread 11-27-2008, 06:17 PM
AKA: Billy
Thanks. I was just wondering thats all.
Unread 12-01-2008, 04:50 PM
AKA: Billy
We were running our benchtest, but we couldnt get tank drive. Everything else worked. Do i continue on with updating the Crio or is there something wrong?
Unread 12-01-2008, 04:53 PM
Just Itinerant
Nothing is wrong. The documentation is a little out of sync with the OTB software load.
Nothing to see here,...move along, move along...
Unread 12-01-2008, 05:46 PM
AKA: Billy
Thanks again.
pic: 987's Early Christmas present 1 KF987 Extra Discussion 13 01-08-2008 11:17 PM
pic: 987's Early Christmas present 2 KF987 Extra Discussion 9 12-10-2007 01:36 AM
pic: Merry Christmas AdamHeard Chit-Chat 6 01-18-2007 01:17 PM
pic: Early Drivetrain Gabriel Mendez Robot Showcase 10 01-28-2006 12:50 AM
pic: 1559 Drivetrain--early bradleym1559 Robot Showcase 2 03-07-2005 07:30 PM
