Re: pic: Madtown Robotics Drive Proto
are those gearboxes custom?
Yes, those gearboxes are custom. For some reason we lost sponsorships but got some weird grants over the summer. We have a brand new CNC, a ton of broaches for keyways and hexes, and other random stuff in our shop. So we figured to start making custom stuff, it's pretty fun. Especially when CD gives such brilliant suggestions. I forgot, in the grant that we wrote for our CNC, it stated that we had to help other teams machine out parts. So i don't know if i should start another thread, but if any teams needs anything milled (can be possible to do with a 3 axis) we would do it for free (you pay for shipping, the product and $1 for the labor/SO as close to free machining.) Contact Me Last edited by R.C. : 28-11-2008 at 16:22. |
where do you get powder-coating done? isent that really expensive?
I work in a custom machine shop that has full CNC capabilities as long with powder coating. Is there a rule against powdercoating in FIRST/ or anything like it?
My employer has allowed us to use all equipment during build season. Do you guys always do that drive train? |
I'm sorry if I'm missing something, but what are those shafts extending from the gearboxes? They don't appear to be attached to anything.
The 1.5 lb gearbox seems fishy to me. What are the gears? Are you accounting for fasteners, cylinder, bearings, shafts, etc...
That being said: Due to all the changes being made to the kit, with electronics and all, don't secure yourself on the CIM motors. Whatever you do, be ready for a change in case it comes. |
This may change in 2009. |
#10
Also as Brandon pointed out, you can't anodize steel. |
#12
Sorry, I didn't mean steel. I was thinking about the aluminum gears.
#13
Regardless of the material, you need to do the math to see if 3/16" face width will work for you. It probably will for the initial reduction, but my gut instinct is there's no way it will hold up on the output. |
#14
Cory I was thinking about this, what if we used a 3/16 face on the first reduction. Then moved up to 3/8 face for the rest, shouldn't that be fine. We are not going to go with an aluminum gearbox yet. In the offseason we will be attempting and testing one out, but for the season it will be steel. I just pointed out that we could anodize if we needed to harden up the aluminum gears(if we used it). I have already checked out your aluminum gearboxes and Cory, if we wanted to make an aluminum gearbox, what steps do you recommend or what is your opinion about creating an aluminum gearbox. We have the time and resources to make one over winter break. But not during the season it we don't make a proto, thanks Cory.
#15
You know what your best bet is if you want a nice, light, simple to make gearbox? Make custom sideplates for the AM supershifters, pocket them like you did, and use standoffs rather than the extrusion casing, like you did. It'll be real fast to make, and you *know* it will work and be very reliable. It may not technically be the lightest gearbox out there, but it will be done fast and done right. You could probably drop the 4.6 lb super shifter to at least 3.5, probably closer to 3 if you lighten the gears (but do not, do not reduce the face width unless you really know what you're doing). A 3-3.5 pound, 2-speed, bulletproof gearbox is still pretty light overall. This is our exact plan on 973. We technically have the resources to make lighter gearboxes (from Steel gears, we won't dabble in aluminum without some serious effort and planning), but it's not worth the additional time and risk in our opinion. |
| pic: Madtown Robotics 07-08 Frame | R.C. | Extra Discussion | 4 | 09-07-2008 17:27 |
| pic: 50% of Madtown Robotics Future Cart | R.C. | Extra Discussion | 4 | 06-07-2008 18:49 |
| pic: Madtown 1323 Proto 2 | R.C. | Extra Discussion | 12 | 20-06-2008 20:27 |
| pic: Madtown Robotics Future Frame Proto 1 | R.C. | Extra Discussion | 31 | 13-06-2008 15:41 |
| pic: Screenshot of Madtown Robotics Team 1323 Website. | Hefner | Extra Discussion | 1 | 02-02-2007 21:18 |
