Go to Post A true form of GP would be to send out a congratulations to all the teams that made it, regardless of whether or not you think they should have. - Molten [more]
  #46   Spotlight this post!
Unread 30-11-2008, 20:25
mcf747 mcf747 is offline
AKA: Matthew Forman
FRC #0190 (Team 190)
mcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud of
Re: pic: Night & Day
Im going to touch on a few points here.....
Originally Posted by Andrew Schreiber
With any luck it will FORCE teams to clean up their wiring and electrical boards.
I do all the electrical for my team and I must say I had the cleanest electrical board and wire harness that I saw at both of the regionals we went too and of any photos I saw. (Not to brag) But I think this is a good thing having a clean rig made it take up much less space and because everything was so clean we had no electrical problems all year.
Originally Posted by Deep Dark
guess we'll just need to not put as much mechanical stuff on inorder to make weight and size.
This has been my though exactly! I have a feeling the game this year is going to be less focused on mechanical abilities and more "smart programming" and "intelligent robots". Some of my team mates have said just the opposite, thinking the game is going to be more mechanical based and less "intelligence" based because of patters they think they have found (we never know with FIRST) which also makes sense because that would allow us to get aquainted with all of this new stuff before we "really" had to use it to its full potential.
Yesterday we figured out a nifty space-saving way to mount these, and I'll post a pic tomorrow night once I put the memory card back into my camera so it will save the picture
Take a 1/16" wall angle aluminum piece that has 2.5" legs (hard to find I know, we had to cut metal meant for another purpose to get it), drill holes that are far enough up and apart so that a Jaguar can be vertically mounted to it. Then, mount the Jaguars back-to-back on the mount -- but -- rotate one of the Jaguars 180 degrees on the axis that's normal to the mount plate. This will put all of the motor outputs on one side and all of the power inputs on the other. Then, using either a 3" #8 bolt & nut, OR a #10 2" machine screw, you can screw the Jaguars to each other. For a production mount piece, you can mill out unnecessary metal from the middle and still maintain the rigidity.
I think this is really clever I have not had much time with the new parts to play with them to much but I think this may become an necesity. Last year I have very little space given to me to do all the electronics to I came up with a "double decker" design but only used the top of each deck. I am thinking about going with a similar design but mounting stuff inverted, to the bottom of each deck and maybe on the side between the decks but I need to get ventilation in there some how.
pic: CRT T-SHIRT Shooter At Night Kyle A Extra Discussion 7 21-09-2006 13:04
pic: Atlanta at Night (cloudy) Joe J. Extra Discussion 7 01-05-2006 21:24
pic: Mayhem Night Crew Tytus Gerrish Extra Discussion 7 11-07-2005 00:55
pic: David Kelly's long night D.J. Fluck Extra Discussion 3 20-03-2005 23:23
pic: 696 - The 1st late night CD47-Bot Extra Discussion 22 17-02-2004 06:45
