Go to Post We live for those eureka moments. Whether we win or lose competitions, it's those moments when a student's idea makes something just "click" that will stick with them and influence them to become engineers. - ToddF [more]
Unread 01-12-2008, 09:51
roboticWanderor's Avatar
Spark The Ancient
FRC #0418 (Purple Haze)
pic: Bane Bots Gearbox CAD
Unread 01-12-2008, 09:52
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: pic: Bane Bots Gearbox CAD
Hey dude,
Any specs on it, reductions? Output Torque and fps would be nice. If you want, send me the animation and I could upload it for you.
-RC
R.C.
MadTown Robotics Team 1323
Unread 01-12-2008, 10:12
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I'm curious - why use the delrin on the sides rather than aluminum? Sure, it's half as dense, but it's also not as stiff and requires a thicker piece and is (in my experience) more expensive.
Unread 01-12-2008, 10:56
I'm curious why the sprocket is on the motor side.
Also, what are the specs of the initial reduction; with the commonality between the various Banebots motors and the FP motors, it seems it would be ideal to make this accept any motor (standardized pinion) and possibly multiple. What are you using as the motor pinion? The 15T 32DP from AndyMark seems to be the best choice on the market.
I've found delrin to be uniformly less expensive than aluminum plate of equal thickness.
Delrin actually works out rather well, you can leave it nice and thick (1/4" for example), not pocket it out, and still be rather lightweight (equivalent to a about the weight of a 3/32" aluminum plate). If the gearbox is designed correctly for the material, it is plenty stiff. A nicely pocketed 1/4" Aluminum plate is usually in the ballpark of a solid delrin counterpart, and the delrin will take less time to produce (you can cut it faster, and by leaving it solid, have less to cut as well).
Unread 01-12-2008, 12:19
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
Assuming this is for some sort of manipulator/arm/elevator, I would assume that the gearbox would be mounted on the inside for added protection to the motor. Obviously, the chain run would be in a more convenient location as well.
Unread 01-12-2008, 17:38
ducttapedude ducttapedude is offline
AKA: Peter
FRC #0233 (The Pink Team)
ducttapedude has a spectacular aura aboutducttapedude has a spectacular aura aboutducttapedude has a spectacular aura about
Send a message via AIM to ducttapedude
IMO Delrin a solid delrin plate ends up being about the same weight as a heavily machined plate of aluminum but not nearly as rigid. I've seen a few delrin gearboxes and you can seem them flex pretty easily, not anything horrible or dangerous, but noticeable. Also, the threading the in the delrin does not last as well, you can use a nut of course, but, just another con in my opinion.
Think Poof
Unread 01-12-2008, 17:51
Engineering Mentor
FRC #0254
^^Agreed. Delrin isn't as great as many people think. We utilized it the last few years strictly for its ease of machining and the reduced weight. I would much prefer a waterjet plate with a quick pass on the CNC to clean up the bores. Access to a waterjet has always been the issue though, but this is something we are looking at for future use.
The strength to weight ratio of delrin is still significantly less than aluminum, and for heavy reduction gearboxes, you need to be very careful with how you use it. For example, we have made some 250:1 arm gearboxes in the past that I would never consider using delrin sideplates with. Just make sure you are using it for the right reasons. Aluminum sideplates also act as great heatsinks, and for games like overdrive, the CIMs could use as much heat dissapation as possible.
-Travis Covington
Unread 01-12-2008, 20:29
CraigHickman
No material is a miracle material; especially not delrin. Each material choice has advantages in specific applications, and thus should be chosen appropriately. Delrin, like aluminum is on the lighter end of the material spectrum. Like Travis said, high torque and heavy reduction applications are best done with something with a little more torsional stiffness.
Delrin does carry certain advantages. Exhibit A: Weight. For most light duty applications in FIRST, such as drive gearbox plates, and lower torque systems, delrin is quite well suited. Its a fairly soft material, which makes machining the plates incredibly easy and fast. It can be less expensive than aluminum of equal size if you know where to look. Exhibit B: Style. Admit it, a lot of teams care about this. Far more than will openly say so. Delrin can be found in nice clean colors, which can add aesthetics to a robot when chosen wisely. Exhibit C: Machine time. Less units of work for more than satisfactory strength make Delrin a mighty tempting material.
However, if a team doesn't spend their time doing some math and stress calculations, the weight gains will be for naught when a major component shears.
Team 114 had great success in building our drive gearbox sideplates out of Delrin. A few tips from what we learned: Washers. If you don't put washers on your bolts, you'll dent the delrin and lose strength. Machining wise, it's a joy to work with. We were able to produce all of our gearbox plates in house on a tiny little desktop CNC. Weight wise, they turned out insanely light.
Unread 01-12-2008, 22:51
Spark The Ancient
This is not that heavy of a reduction, just 24:1. the only thing i am really worried about is the mount of the actual motor, I had to bore into the delrin a bit to get the motor pinion far enough out the other side, making the material that holds in the motor is 1/8 thick instead of 1/4 like the rest of the gearbox. However, it's a pretty high rpm, low torque motor, so I wouldn't expect it to be taking much force, plus it has thicker material surrounding it...
Oh, and i cant show the video because solidworks does not like to encode it correctly... =(
Unread 01-12-2008, 22:53
CraigHickman
The banebots motor should be fine with this. If you were mounting a CIM on that, it would be an entirely different story....
Unread 02-12-2008, 00:08
run the trap!!!
Team Role: Human Player
We saw the 254 gearboxes in 2007 and were like: "ABS! Of course! Why didn't we think of that!?"
We bought some .25" ABS scraps at Tap for 50 cents each and used them in the trannies.
Had we thought to ask 254 about their robot we may have discovered that they were actually using delrin which is about .4 g/cm^3 denser.
-Philip J. Fry
Unread 02-12-2008, 00:19
R.C.'s Avatar
How did the plates hold up.
R.C.
Unread 02-12-2008, 01:47
run the trap!!!
They held up fine.
The elevator gearbox was just 3/16" ABS and it survived 100+ hurdles as the elevator slammed up and down.
-Philip J. Fry
Last Years Bane Bots Gear Supports CollmandosGrl General Forum 1 27-01-2008 14:54
Bane Bots Gear boxes not allowed? Skute327 Motors 4 13-01-2008 12:08
Bane Bots transmission sieze Demothesis Motors 3 31-03-2007 21:55
Anyone Not Using Their 56mm Bane Bot Gearbox? fhsteam613 Motors 3 22-02-2007 12:59
Mini-bike motor on the bane bots gear box free_rider_151 Technical Discussion 2 12-01-2007 21:17
